Sponsored by: Real Truck
Freshly Rebuilt 4R100 shift problem...
Old Jun 17, 2013 | 08:52 AM
MDrumm03's Avatar
MDrumm03
Hey all, just got my transmission (4R100) completely rebuilt professionally along with a new TC, by a friend of ours who works at a transmission repair shop. I put the transmission back in last night, filled it full of fluid while it was running, as well as threw in a quart of lucas... I have all my gears P,R,N,D,2,1... but for some reason when the truck is in drive it will not shift out of 2nd.. into 3rd that is... gets to about 2,200 - 2,300 range at about 35 mph and will not shift. Now, if I really get on it, it will act like its going to shift to 3rd but just put itself back into 2nd... I really don't think he messed up rebuilding the transmission considering we've taken about 4 to him and never had a problem but I suppose anythings possible... We're thinking it might be a sensor of some sort? Still waiting to hear back from him, but in the mean time I'd see if anyone on here had some ideas...
Thanks a lot!
Old Jun 17, 2013 | 09:20 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I don't know of any sensor that could do that. It could be a bad shift solenoid, or a stuck shift valve, or a problem with the direct clutch, or some other thing I haven't thought of.
Old Jun 17, 2013 | 10:49 AM
redford's Avatar
redford
FTE Leadership Emeritus
Is the shift linkage adjusted properly?
Old Dec 16, 2023 | 06:24 AM
Tmantz's Avatar
Tmantz
5th Gear
I believe so the back up lights come on when I go to reverse.
i installed a new linkage also. I put it where the old one was, it lines up on the dash with the gear I put it in. And my scanner also gives the gear and all match.
Old Dec 16, 2023 | 06:32 AM
Tmantz's Avatar
Tmantz
5th Gear
I see I am going to pull the valve body all three and recheck them see if one is not rite. And recheck the shift linkage . Thank you I will keep y'all posted of findings.
Old Mar 30, 2024 | 07:22 PM
Tmantz's Avatar
Tmantz
5th Gear
I Finally got the problems out of my 4R100
I Finally got my truck back going again. It was a check ball out of the hole and a gasket with one pin hole not rite. Maybe the one way sprag. Not for sure. It did go good shifting first to second o 3 or 4. I Fixed it and it got worse. Going into drive and reverse no shift at all. Anyway it is good now I put new intermediates they burned a little still good but I wanted to make sure they were. Anyway to many mods to list shifts great and firm no leaks pressure was 120 at idle. Around 250 going down road 45. Quit
​​​​​checking after that. So thank you guys for all your advice and knowledge.
1990-f250
Apr 13, 2014 08:52 PM
reel_scream
Oct 18, 2004 08:58 PM
