Sponsored by: Real Truck
1.5" In The Front
Old Jun 16, 2013 | 09:05 PM
kmc0929's Avatar
kmc0929
1.5" In The Front
2006 F-250 W/5200# Front Coils, looking for the best way to get up to or below 1.5". Biggest question is, will this height require a trackbar relocation bracket?
Ford F-550 7000# Coils $200 for the pair from Ford
Rough Country 1.5" Lift Coils (Progressive) $180 Online
Skyjacker 1" Leveling Kit (Sits Below Spring Perch) $100 Online
Ready Lift 1.5" Leveling Kit (Sits Below Spring Perch) $150 Online
I'm leaning towards either the Ford or Rough Country coils. Assuming an alignment is the only thing needed after install? Axle will still be centered under the truck?
Old Jun 17, 2013 | 06:20 AM
MC5C's Avatar
MC5C
The F550 coils will be solid like a rock at 1800# more than your stock springs, they would be my last choice unless you are doing this so you can plow. I would choose the progressive springs because I value a smooth ride. At 1.5" lift you can probably get away with the stock pitman arm and track bar, the axle shouldn't move more than a half inch. Alignment needed to recenter the steering wheel, maybe, and put caster back at 3 - 4 degrees positive.
Brian
SCFlareside
Aug 22, 2018 04:50 PM
ford_racing_4_life
1983 - 2012 Ranger & B-Series
15
Jan 11, 2007 03:52 PM
dehamma
Oct 29, 2003 08:58 PM
fatfenders
1978 - 1996 Big Bronco
Sep 17, 2003 07:22 PM
joecool
Mar 12, 2001 01:49 PM
