touchy rear brakes.
Old 03-14-2016, 06:08 AM
RadioControlGuy85's Avatar
RadioControlGuy85
RadioControlGuy85 is offline
touchy rear brakes.
hey guys,
my 92 f150 with the rear abs are a bit touchy. if you haven't drove the truck it will almost put you through the windshield.
how do you set the rear brakes?
it has new wheel cylinders and brake pads. im just wondering if there not set right.
thanks
Old 03-14-2016, 07:03 AM
My4Fordtrucks's Avatar
My4Fordtrucks
My4Fordtrucks is online now
Received 1,405 Likes on 1,110 Posts
Were they like that before replacing the wheel cylinders and shoes? Are you sure the wheel cylinders are the correct size replacement? The star wheel sets the adjustment. How (tight) did you adjust the shoes?
Old 03-14-2016, 07:27 AM
Lead Head's Avatar
Lead Head
Lead Head is offline
Are you sure it's the rear brakes? Generally if the rear brakes were set incorrectly (say too tight), the drums would get extremely hot after a drive. If they were set to loose, they just won't do anything.
What makes me think it might not be your rear brakes, is that the rear brakes on an unloaded truck are just about useless and have almost no stopping power at all. They'll just start to lockup with the truck hardly slowing down at all.
Old 03-14-2016, 09:34 AM
Mudsport96's Avatar
Mudsport96
Mudsport96 is offline
Mine do it after it rains and it hasn't been driven. Once I stop a few times they are normal.
Old 03-14-2016, 10:43 AM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,173 Likes on 927 Posts
Both of my '93 Lightnings exhibited this behavior.
Old 03-14-2016, 03:56 PM
RadioControlGuy85
yes it was like this before the new stuff was installed.
yes its the rear brakes because you can feel them locking up.
as stated above you can drive it for awhile and there ok. but if it sits for a little while like a week it will go back to being touchy rear brakes.
Old 03-14-2016, 04:12 PM
rla2005's Avatar
rla2005
rla2005 is offline
I learned to apply a slight amount of pressure on the brake pedal to warmup the brakes. Worked like a charm within a few hundred feet. Otherwise if I hit the brakes at the end of the drive the rear wheels would skid in the gravel. If I drove the truck everyday, very little issue.
Old 03-14-2016, 04:54 PM
westcoasting's Avatar
westcoasting
westcoasting is offline
Identical issue in my '96, same solution too!
Old 03-14-2016, 05:37 PM
Evan_P's Avatar
Evan_P
Evan_P is offline
Millam
10-27-2018 12:36 AM
BigBlue92
1983 - 2012 Ranger & B-Series
05-22-2012 09:34 AM
2020
06-21-2011 05:10 PM
wmiller
01-19-2008 08:28 PM
tripp1
1997 - 2003 F150
12-07-2003 03:07 PM
Quick Reply: touchy rear brakes.
