95 psd wont start
Old Jun 15, 2013 | 12:26 PM
Powermonger's Avatar
Powermonger
95 psd wont start
my 95 psd wont start its started doing it about two weeks ago, I would try to start it and it wouldn't I would wait a minute and it would it wouldn't do it all the time then yesterday I had to wait an hour now it wont start at all my fluids are right when its running it runs awesome and replaced my fuel pump two years ago im wondering if its my hpop or my fpr how do I test these or might it be something else?
Old Jun 15, 2013 | 01:32 PM
fordpride's Avatar
fordpride
Are you getting smoke from the exhaust ?
Old Jun 15, 2013 | 05:11 PM
Powermonger
yes wasn't at first but then it does
Old Jun 15, 2013 | 06:30 PM
427 fordman's Avatar
427 fordman
Have you ever changed the cam sensor?
Old Jun 15, 2013 | 07:03 PM
Powermonger
no and I and my ipr was loose I tightened it is that supposed to be in a certain position and is there a way to test the cmp
Old Jun 15, 2013 | 07:45 PM
Powermonger
can I test the cam sensor?
Old Jun 15, 2013 | 07:49 PM
427 fordman
Not that I know of. They are a common failure point, and sounds like it could be your problem. You should even carry a spare, they can fail that often. Don't get one from a parts store though, they sometimes don't even work. Get it from ford or IH, its only about 25 bucks.
Old Jun 15, 2013 | 08:01 PM
Powermonger
my oil in the hpop is about inch and a half, two inchs down
Old Jun 15, 2013 | 08:06 PM
427 fordman
That's probably from extended cranking. You could top it off and try it. Make sure your batteries are fully charged. I assume you meant the ipr tin nut was loose and not the ipr right? I've had mine start with the tin nut laying in the valley. It started cranking longer before it started so I looked and found it had fallen off.
Old Jun 15, 2013 | 09:51 PM
fordpride's Avatar
fordpride
Top off the hpop oil and let it sit overnight and see if it drains down again. Don't try to start till after you know if it drains back
Old Jun 16, 2013 | 02:31 PM
Powermonger
thanks you guys, I replaced the cam sensor but I had already bought from advanced before I had seen your post so now im back to wondering if that's what it is, also hooked it up to a scanner and it said no codes to test the pressure at the shrader valve the truck has to be running right sorry still trying to learn
Old Jun 16, 2013 | 03:00 PM
427 fordman
No parts store scanner will get the codes off these trucks, if that is where you checked for them at. It takes something a little better as these aren't fully obdII compliant.
If you got a faulty cps from advanced auto, it wouldn't be the first time.
Old Jun 16, 2013 | 03:07 PM
Powermonger
filled the hpop tried to start it,for a second it almost started,so I filled the pump up gonna let it sit
Sailor182
76
Apr 5, 2012 11:00 PM
dthompson
78
Jan 1, 2010 09:34 AM
kawa
Mar 8, 2008 09:09 AM
Ford from above
Jun 1, 2004 07:43 PM
