Disabling '92 F150 Buzzer
Old Jun 9, 2003 | 10:30 PM
92 Red F150's Avatar
92 Red F150
I am wanting to disable the key in the ignition/open the door buzzer, it's got to go! So I did a forum search and only turned up an old thread on doing this to a newer F250SD. I read enough in the thread about the inherent problems of doing this (at least on the newer models) that I thought I ought to ask somebody on the forum about it. Specifically, has anybody disabled the buzzer on a 1992 F150 ( or model years close to)? What exactly is involved? Is it as easy as pulling the buzzer itself or maybe cutting a specific wire? Thanks, Charles
Old Jun 10, 2003 | 12:35 AM
charlez's Avatar
charlez
Ok, this one's pretty easy. (that thing is annoying). If you do it this way, it will still chime with the headlights on and can be easily reversed.
-Remove the plastic colum cover (3-4 screws out the bottom)
-turn key one position forward from lock
-use small item to push release pin
-Pull key/tumbler assembly out
-locate the key chime switch
-just slide it out
-wrap it up in some electrical tape
-reinstall the tumbler (without the switch)
-reinstall the plastic cover (the taped up switch will fit under the cover
Old Jun 10, 2003 | 10:55 AM
92 Red F150
Charlez, thanks a ton for the reply! That looks like an easy solution and no cutting needed. The best thing of all is I had to replace the ignition cylinder anyway as it is bad- 2 birds with one stone! By the way, those were great pics. Thanks for your input and effort, this forum is great. Charles
Old Jun 14, 2003 | 09:17 PM
truckfanactic's Avatar
truckfanactic
You can also unplug the door sensor that also controls the dome light when the door is open
Old Nov 24, 2003 | 08:04 PM
92 Red F150
charlez, I'm a slow worker! Just got around to replacing the ignition cylinder tonite. While I was in there, I disabled the key chime switch per your procedure. Works like a charm, no more annoying buzzer! Thanks, Charles
Old Nov 24, 2003 | 08:48 PM
acerockola77's Avatar
acerockola77
I pulled mine out and ran over it several times, shortly after getting my truck.
Old Nov 24, 2003 | 08:53 PM
92 Red F150
HAHA My sentiments exactly!
Old Jan 1, 2004 | 07:59 PM
79oneton's Avatar
79oneton
1996 F-150, Why can't I unplug the wiring harness to the buzzer box to achieve this
Old Jan 2, 2004 | 01:17 AM
charlez's Avatar
charlez
92 Red F150, wow you get around to stuff about as quick as I do. You're Welcome, glad to help.
79oneton, Yes, you can just unplug chime module. I didn't because I wanted to retain the chime for the lights on warning.
Old Jan 2, 2004 | 09:15 AM
79oneton's Avatar
79oneton
thanks charlez, no more annoying noises for me. I bought this truck last summer, I'm really looking for 97 F-350 4x4 powerstroke single cab
jmuenchow
Jul 9, 2015 08:22 AM
ddeflyer
Feb 10, 2015 01:58 PM
bills86f150
Dec 20, 2014 06:38 PM
anthony605
Jan 4, 2004 08:17 PM
