Tire size concerns
Old Jun 14, 2013 | 07:16 PM
Orange84's Avatar
Orange84
Tire size concerns
I am in need of new tires and am wondering what size I could get with stock 15 inch rims with a width of 7.5 inches. I understand the truck comes stock with 235/75/15 tires but I want to beef it up a little and yet not harm my brand new tires. I know the clearance for these tires is fine but I don't want any crowning to happen. Would I be safe with 31/10.5/15 tires on my stock rims?
Old Jun 14, 2013 | 07:48 PM
78 & 87 Super Cab's Avatar
78 & 87 Super Cab
I'm running P255/70 on the rear,and P235/70 on the front of My '80, no issues whatsoever
Old Jun 14, 2013 | 08:01 PM
85e150's Avatar
85e150
I ran 31-10.50x15s on Centerline wheels marked 15x7 without problems, fwiw.
Last edited by 85e150; Jun 14, 2013 at 08:19 PM. Reason: clarify wheel type and width
Old Jun 14, 2013 | 08:17 PM
LongRider's Avatar
LongRider
How are you measuring rim width ??
INSIDE flange to INSIDE flange is correct.
Many measure outside to outside, which is WRONG and will yield a measurement about an inch greater than true rim width.
Standard issue factory rims were usually 6.5"
Old Jun 14, 2013 | 09:16 PM
Franklin2's Avatar
Franklin2
31x10.50x15's will rub a little bit on the radius arms when you turn sharp in the parking lot. They may also rub a little bit in the back on a bump if you have the truck really loaded down, like a heaping load of green firewood. Nothing bad though, you can live with the little bit of rubbing with the 31's without too much trouble. You will have to be careful with your inflation pressure, if you run them to the max with that smaller rim, they can wear in the middle(but my stock rims were 6 inches wide).
If you run aftermarket rims like the other poster did, they they will not rub the radius arms and if they are 8 inches wide they will not wear in the center either. They still will rub a little bit in the backwhen loaded down, but you will have to decide if this will be a problem depending on how you use the truck.
P.S. My rubber suspension stops were missing on my truck in the rear, so that might be the cause of the rubbing when heavily loaded. If you still have your rubber stops they may keep the suspension from flexing up enough to hit the plastic liners in the wheel wells in the back.
Old Jun 14, 2013 | 11:34 PM
Orange84's Avatar
Orange84
Well I have 2 sets of rims both 7.5 inches I just don't want to end up ruining my new tires since new ones aren't cheap. I have my truck leveled and still have my rubber bumpers so rubbing wont be too much of a problem. Just don't want crowning.
Old Jun 15, 2013 | 12:55 AM
85e150's Avatar
85e150
Are the wheels stamped "15x7.5"?? Stock steelies are like the previous poster said, usually 6.5".
Old Jun 15, 2013 | 01:39 AM
Orange84's Avatar
Orange84
Well I measured from the inside lip to the inside of the other lip and it measured 7.5 so I would assume its 15x7.5 if I am not mistaken.
Old Jun 15, 2013 | 01:18 PM
Franklin2's Avatar
Franklin2
I believe they will be ok. When you get them installed, get some chalk and draw a line across the tread. Then drive it forward a few feet on pavement, and see if the chalk is rubbed off most of the tire. You can vary the air pressure to get what you want.
Old Jun 16, 2013 | 08:58 AM
dylansf23's Avatar
dylansf23
I'm running 37" military tires ....put about 4k on them...still aligned perfectly, and my truck has no lift, and only rubs the leaf spring on a far left turn. Your tires will be fine
Old Jun 16, 2013 | 11:38 AM
1983F1503004x4's Avatar
1983F1503004x4
I'm not saying you don't have 37'' tires... but your truck has to be an F250 or an F350 (leaf springs clued me in).
An F150 can only fit up to about 34.5'' of rubber, stock
Old Jun 16, 2013 | 01:29 PM
Rovernut's Avatar
Rovernut
Most tire makers will have on their web site charts showing tire sizes and approved rim width for each. For instance:
CooperTiresConsumer - Discoverer S/T<span class='trademark'>™</span>
Column 6 is approved rim width.
Old Jun 16, 2013 | 04:57 PM
dylansf23's Avatar
dylansf23
yes it is, i totally forgot about how much bigger the f250 is, and its 4x4 i also forgot how the 250 has a 2inch block in the rear
Björn
Dec 6, 2017 04:57 PM
boboh1
Jun 23, 2012 06:30 PM
Craigwell
Nov 18, 2009 06:33 PM
DCRB
Aerostar
Dec 8, 2007 09:17 AM
mikeberman04
Sep 16, 2002 09:32 PM
