Sound gurus
Old Jun 14, 2013 | 01:31 PM
Ford4Life7.3's Avatar
Ford4Life7.3
Sound gurus
Hey guys, I'm about to buy 2 12" subs from a friend and plan on building a custom box to put behind my rear seats. The Previous owner had a custom box back there and it sounded good, however they did not come with the truck. My question is this- The subs arent shallow subs, theyre regular old 12's. Will they work on a box behind the seat and not take up too much room? Im going to port the box on the ends facing the doors, but the space behind the sub will have to be limited...will this still sound okay?
Old Jun 14, 2013 | 01:51 PM
dieselsubmariner's Avatar
dieselsubmariner
i build a box for my crew cab with 2 10” alpine subs and run those on a mrp500 mono amp. A lot of people think, those subs are bigger, because of the sound. The box goes all the way across, and has a center divider. It is not ported. I build it out of 3/4” mdf. it is about 8 inches wide at the bottom, 4 inches up top and as high as the seats.
Up front i run 6 1/2” component speakers with Tweeters up on the fwd corner of the door panels. they are Alpine as well. Radio is a alpine with cd and bluetooth.
Old Jun 14, 2013 | 01:52 PM
dieselsubmariner
ohh.. check out cowboom.com this is where i buy usually my sound equipment from. its used, but great prices
Old Jun 14, 2013 | 03:36 PM
Ford4Life7.3
How deep are your subs though? Are they standards or shallow subs?
Old Jun 14, 2013 | 03:39 PM
dieselsubmariner
Can't remember how deep , but they were not the shallow ones
Old Jun 14, 2013 | 04:52 PM
strokin'_tatsch's Avatar
strokin'_tatsch
What model subs are you looking at? If your not sure, do you at least know how deep they are?
Even with the knowledge that they aren't shallow mounts, we can't know how deep they really are without the model # or a measurement. A model # would be best so I can see how much air space they will need for a ported or sealed box. We also have to know how much space you have behind the seat. Measure top of the seat to the back of the cab and bottom of the seat to the back of the cab and measure the width you have.
I have some 12" Alpine subs out on the shelf that are 4 1/2" deep, then I have some JLs that are around 7 1/2" deep. So as you can tell, there is a pretty wide range of mounting depths out there and why it would be helpful to know exactly what you have to determine whether they will actually fit and if you'll be able to build a box to suite them in your truck.
Old Jun 14, 2013 | 05:08 PM
Ford4Life7.3
Thanks for the reply man. Here is a link to them
Audiobahn DUB200 12" DUB Series Dual 4 ohms Subwoofer w/ Grill
Ill go out and measure the space behind my back seat. Im not sure as im in the middle of doing the SD seat swap so i have to see where i want to mount the seats as that will determine how much room i have.
Old Jun 14, 2013 | 05:43 PM
strokin'_tatsch
Ok. 6 3/8" mounting depth should be ok to fit back there. Looks like the minimum ported box air space you need is 1.2 cu ft. per sub with a 3x6.75" port. From what I read, that sub would be happier around 2.2-3.1 cu ft though in a ported box and of course port size increases with more air volume as well. I've never built a ported box so when it comes to port velocity and port shapes, I get lost.
Personally I'd just run a sealed box and see how it is. That sub needs a minimum of 0.75 cu ft and a maximum of 1.5 cu ft per sub in a sealed box. From what I understand the more air space you provide in a sealed box, the deeper the tone will be from the sub, but it won't hit as hard. The smaller the box, the higher the tone, but the harder the sub will hit. So a happy medium would be around 1.0-1.10 cu ft in a sealed box. That should be do-able behind the seat of your truck.
So if you have the space to get around 1.2 cu ft per sub, you could try the box sealed and ported and decide which you like better.
Something I did for the last system I built to keep in mind if you run into this problem. I didn't have enough mounting depth in the box to fit the sub, I needed about 1/2" more depth and was using 3/4" MDF. So I cut out the back of the box so the magnet would sit down in the hole and then covered the back with another piece of MDF. That let the magnet side down in the box a little bit with about 1/4" to spare and the box still fit under the seat. Those subs sounded really good, so I don't think the magnet being so close to the box hurt anything.
Sycostang67
Oct 18, 2009 12:37 AM
u1cracka
Apr 25, 2008 08:02 PM
brownh20GM
Jan 5, 2005 03:56 PM
dynocompe
Jun 28, 2004 11:37 PM
Marc150
May 28, 2004 12:06 AM
