Gunk (oil in degas). Bad oil cooler i know.
Old 06-18-2013, 01:48 PM
droffan's Avatar
droffan
droffan is offline
Cleaned out the degas
Originally Posted by wrongway01
Your oil cooler is no good. I use stock Ford oil coolers myself. After you install the new oil cooler add about 3 table spoons of Dawn dish washing soap and let it run awhile. Drain and repeat until all traces of oil are gone. And you might want to consider buying a new degas bottle because your old one will never clean up enough to be able to see the coolant level. Ford also sells a quart bottle of cast iron block cleaner that will get everything out of your coolant passages. Flushing is just a long and nasty process that you are going to have to do. Hope this helps
filled it in the kitchen sink with plenty of dawn and hot water, shook it all up and left it over night. clean and now i am going to do the simple green, pull block plugs, buy all new hoses and see what transpires.
Old 06-18-2013, 03:53 PM
BPofMD's Avatar
BPofMD
BPofMD is online now
Received 1,135 Likes on 1,031 Posts
If you don't replace the oil cooler you are wasting time and money! But.... it's YOUR time and $.......
Old 06-18-2013, 04:38 PM
droffan's Avatar
droffan
droffan is offline
$1500 vs two days of eliminating issues
is worth it....ford here in Portland is $1500, thats next if this simple green flush along with new hoses and pulling block plugs at thermo (which i didn't do it before)
thanks...
Old 06-18-2013, 04:42 PM
mustang_309's Avatar
mustang_309
mustang_309 is offline
The problem is if you didn't replace the oil cooler after you found the oil in the coolant you will not get the oil out because the oil cooler is still leaking oil into the coolant system.
Jeff heine
22
12-30-2015 05:17 PM
Rocky RaetzIDI
12-22-2013 10:52 PM
john11139
05-14-2011 07:42 AM
benbe71
15
06-09-2010 01:07 PM
d_stange
05-02-2007 07:52 AM
Quick Reply: Gunk (oil in degas). Bad oil cooler i know.
