Need Help please with miss
Old Jun 15, 2013 | 12:33 PM
#1fordguy's Avatar
#1fordguy
I've tried every possible thing.My expy 4.6 171xxx has been missing randomly its never a constant miss its never threw code..I've replaced fuel pump,plugs-n-wires,coils packs,tps and egr along with all rubber hose vacum lines..I've cleaned two different iac with no luck..Seems to miss noticeable at a stop when in gear could take 2 -3 mins before it does a random buck of drop in rpm while sitting waiting to leave light then its very sluggish as i leave the light and passing on freeway ..I checked for spark by pulling the wires off the coils one by one they all had strong constant spark.it seemed to be more of drastic miss when spark was removed from cylinder than the miss I have...Thanks in advance for any help..
Old Jun 15, 2013 | 01:55 PM
alloro's Avatar
alloro
Based on your description it sounds more like a bad wire connection to me. Find it could prove to be difficult. Have you tried shaking various parts of the wiring harness and connectors to see if the engine is affected?
Old Jun 16, 2013 | 01:10 AM
wastingas's Avatar
wastingas
Might be crazy idea but for the sake of brainstorming, did you take out the maf and wipe the two little wires to make sure there clean.
My next idea would be pre-detination caused by carbon build-up on the pistons or heads. (i know its not too common on these motors)
I have cleaned the internals by getting the motor hot and then with the motor at idle sucking seafoam (or similar) into the intake manifold I use the brake booster hose.
Old Jun 16, 2013 | 12:55 PM
alloro's Avatar
alloro
FYI, it is not recommended to ever touch the MAF wire because of it being so fragile. The safer way is to spray it with a cleaner and then give it a small shot of compressed air.
Old Jun 16, 2013 | 01:09 PM
#1fordguy's Avatar
#1fordguy
I was think a bad wire conection or bad wire could be it too.I havn,t tried shaking the harnnes though try that too..thanks for the re:
Old Jun 16, 2013 | 01:11 PM
#1fordguy's Avatar
#1fordguy
Yes, I have cleaned the maf with spray cleaner.Thanks for re:
Old Jun 16, 2013 | 10:46 PM
pdqford's Avatar
pdqford
How about the infamous PCV elbow?
Old Jun 16, 2013 | 10:54 PM
wastingas's Avatar
wastingas
Not under minding you because all your posts are pretty insightful but I've . cleaned crud off MAF wires with scribes or needles very genitally wiping them on tons of vehicles with great results.
Old Jun 16, 2013 | 11:51 PM
#1fordguy's Avatar
#1fordguy
I did check it.My pcv valve has a hard rubber hose that I couldn't pull off but looks to be crack free.I think the the pcv elbow is on the 5.4..I'm think about replacing the iac next although I dont think its going to fix it at my wits end now..I'm starting to think the worst a slow leaking head gasket letting moisture in a cylinder.
Old Jun 16, 2013 | 11:55 PM
#1fordguy's Avatar
#1fordguy
I'll try it I have done this before with the maf cleaner and Q-tip at this point i will try anthing..Just keep hoping for a code mil light...Thanks for re..
Old Jun 17, 2013 | 12:12 AM
#1fordguy's Avatar
#1fordguy
Today I tried testing the evr and iac both seem to be working right..Tried the blow threw and grounding out pin 33 to see if it let vacuum to the egr which it did making the engine try to stall..As for the iac test i just unplugged the wire connector and unplugged the intake vac hose connected to the housing both caused a drop in idle I'm just assuming its good based on that..A weird noise has been happening latey too just to add to the headache, only three times in the past week .First time I was siting in the garage car in gear foot on brake then there it went it sounds like a air horn loud bloot..lol..then it stops sat in the car today for 30 mins in gear and it never sounded..Anybody heard of this..Evr maybe thanks for any re
Old Jun 17, 2013 | 12:33 AM
khadma's Avatar
khadma
Carpenter Local 745
You can clean the passage ways around the MAF sensor wires, but like mentioned earlier you should not
touch the wires, just spray them.
Also have you actually checked the computer with a scanner?
Please STOP throwing parts at the truck for now.
Look for an air leak after the MAF and before/at the intake.
Inspect connections, hoses and grounds.
Always disconnect the negative battery cable when doing ANY electrical work.
Systematically go back over all the parts you replaced (keeping in mind that new parts can be junk too).
Old Jun 17, 2013 | 03:00 AM
#1fordguy's Avatar
#1fordguy
I did clean maf with spray only
[/QUOTE]Also have you actually checked the computer with a scanner?[/QUOTE] I just have a obd code reader no codes with that.
[/QUOTE]Please STOP throwing parts at the truck for now.[/QUOTE] Ya im on tight buget right now cant afford it.
[/QUOTE]Look for an air leak after the MAF and before/at the intake.[/QUOTE] I have the k&n cold air intake I did spray carb cleaner all around it with change in idle but will def check again.
[/QUOTE]Inspect connections, hoses and grounds.[/QUOTE]check
Systematically go back over all the parts you replaced (keeping in mind that new parts can be junk too).[/QUOTE]Will do..new parts fuel pump im kind sketchy on ebay pump fuel pressure test shows (35psi key on engine off) (26 psi at idle fluctuates when reving 26-30 psi) 39 psi reg vac hose off..Thanks for re..
Old Jun 17, 2013 | 03:56 AM
khadma's Avatar
khadma
Carpenter Local 745
Uh, mentioning that this truck has CAI is/was important.
So, you have a K&N reusable oil air filter?
And you noticed idle change while spraying carb cleaner on intake AFTER
The MAF?
Vacuum leaks after the MAF cause "stop light" miss/stumble.
Old Jun 17, 2013 | 03:46 PM
pdqford's Avatar
pdqford
We call that noise the "moose call" ! Just a steady, weak, horn like sound. (My Navigator will do that once in a while if the outside temp is < 20 degrees.)
One fella on this forum changed his IAC and it hasn't happened since.
https://www.ford-trucks.com/forums/1...-fog-horn.html
