Does anyone sell (or have some you want to sell) the triangular pieces that the door screws to on the cab side? I royaly screwed one up getting the hinges off and it is no longer usable even if I tried re-thread it.
Thanks,
Matt
Make a new one. They aren't that complicated. I even considered drilling mine out and putting nuts on the back of the hinge screws but was able to save the old threads.
You might also want to contact 51Panelman on this forum. He has a lot of parts and may be able to help you out...
I was thinking spool arc easy grind. Mind you, I haven't tried tapping it. I have the facilities to anneal in my "shop."
I strongly agree that making a new one is far more straightforward but I thought he stated that he didn't want to do that. Anyway, I blame it on the pain med's. The new knee is rockin'! I'm very happy with it. Drool..
Good luck with your knee - did you get a full replacement? I play tennis with an emergency room doctor who had both knees replaced within the last 3 years. He gets around great and has no problems with them.
Back on Topic, I took my doors off and almost every one of the bolts broke off in the plates. I am going to make new ones using the hinge as the template to get the holes lined up. I will be working on my doors next, so I need to get busy. Maybe Number Dummy knows where some are...
Spent some time in the shop ths morning and got it fixed, just ended up making a new one out of some extra plate I had laying around. Thanks everyone for the comments and advice!
