Electric fan conversion
Old Jun 13, 2013 | 01:16 PM
Alex from GA's Avatar
Alex from GA
Electric fans draw a lot of current; you'll have to upgrade your alternator.
Old Jun 13, 2013 | 05:39 PM
bradb2230's Avatar
bradb2230
second that.... Mine draw 25 amps each...... the old 60 amp alternator was not cutting it......
During the installation make sure that your grounds are super solid and to the frame or battery, not to any of the sheet metal. each fan needs it's own relay, I am using three. one for each fan and one that I have hooked to a toggle switch that turns them both on. I also have a temp switch that will kick the fans on automatically when water temps reach 180. the toggle switch is a fail safe in the event the temp switch fails.
Derale 16927 Derale High-Output Dual Fans
Old Jun 13, 2013 | 11:31 PM
Ford 67 Ford's Avatar
Ford 67 Ford
Nice setup you got there Brad. Eventually I may go electric but since I'm not drivin my '67 a lot right now, my old steel fan without even a clutch is adequate for the time being. Later.
Old Jun 14, 2013 | 05:40 PM
67-F100's Avatar
67-F100
i know. i was gonna do a 3g upgrade if i run one.
Old Jun 14, 2013 | 07:38 PM
tasboj's Avatar
tasboj
This is how I did mine.
Volvo relays.
BMW temp sensor 180*.
thunder bird mid 90's fan.
CdnWillyG
13
Aug 21, 2020 04:35 PM
Curated Content Editor
General Automotive Discussion
Jun 7, 2017 01:20 PM
tabascom16
Jan 19, 2015 06:48 AM
Tomc750
May 18, 2014 07:00 PM
Aaron-71
32
Aug 26, 2011 10:30 PM
