Cooling fan
Old May 16, 2014 | 07:04 PM
Tomc750's Avatar
Tomc750
Cooling fan
My 77 F250 with a 460 is missing the radiator shroud and also has a bad fan clutch. Rather than replace those items I believe I'll install an electric fan. I may occasionally do a bit of towing with the truck. So my question is this: Should I buy a single 16" fan or a double 12"which is way more expensive?
Old May 16, 2014 | 09:15 PM
HIO Silver's Avatar
HIO Silver
Screw them dinky fans.. get the monster Lincoln Mark VIII or T-bird fan. It'll suck a cat flat to the grill:
Electric Fan/Cooling Upgrades
Ford Muscle: Lincoln Mark VIII Retrofit
Fordification Thread: Lincoln Mark VIII/T-bird Two-Speed Fan Installation
Pro-Touring.com Thread: Mark VIII fan & SPAL Controller
Hollister Road Electric Fan Components
The Fan Man - Electric Fans & Controllers
Nasty Z28 Thread: Budget Dual Electric Fan Controller Set Up
FTE Thread: akforceten's 1972 F250
Centech Fan Controllers
Mocked up with custom brackets:
Installed on my 360FE Bump:
Old May 16, 2014 | 09:50 PM
bucks77ford's Avatar
bucks77ford
The Fan above would be the cheapest route to go for a E fan setup. I do have a dual fan derale setup on my 77and it works great, but not cheap. Also keep in mind that large E fans use some amps, so an alternator upgrade may be in store for ya. I have a 110 amp alternator on my 77. My dual fan setup uses 50 amps total.
Old May 17, 2014 | 08:45 AM
lafermedavid's Avatar
lafermedavid
e fan
Hey Buck ,try to post some pics of your dual fan setup
Old May 17, 2014 | 10:19 AM
Fordworth's Avatar
Fordworth
Originally Posted by HIO Silver
Screw them dinky fans.. get the monster Lincoln Mark VIII or T-bird fan. It'll suck a cat flat to the grill:<br />
<br />
<br />
X2. That's a proven unit as evidenced by its popularity. I was hoping to use one on my truck but I don't have the space for it. As far as the cost goes, I picked up two of them a the PYP for $24 each on 1/2 price day. I gave one to a buddy for his rock crawler project and it works great. <br />
The alternator upgrade is a must if you haven't already done it. Look up 3G upgrade, it's a cheap and easy way to add a 130 amp unit.
Old May 17, 2014 | 07:43 PM
Tomc750's Avatar
Tomc750
Not familiar with PYP or 3G upgrade, could you elaborate?
Old May 17, 2014 | 07:46 PM
Fordworth's Avatar
Fordworth
PYP= pull your pary, aka self serve wrecking yard.
3G= 3rd generation Ford alternator.
https://www.ford-trucks.com/forums/9...g-upgrade.html
Old May 17, 2014 | 11:49 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
More info about it....
Lincoln Mk VIII two-speed fan, Taurus or Lincoln cars
A 95 Mercury villager minivan with a 3.3L V6. The stock radiator for this thing was a gigantic three core all aluminum radiator
However, the fan for this was a gigantic 19" two speed fan. This thing is massive. Bigger than a mark viii.
If anyone's interested, I did some research the 92-2002 Villager is a rebadged Nissan quest.
Old May 18, 2014 | 07:00 PM
Ordnance's Avatar
Ordnance
I discovered this too a while back. Still waiting on the install. Now i need tires.
CdnWillyG
13
Aug 21, 2020 04:35 PM
Hongster
Jan 30, 2012 06:47 PM
Aaron-71
32
Aug 26, 2011 10:30 PM
my1993XLT
Feb 4, 2008 07:25 AM
Pablo-UA
Aerostar
Nov 13, 2005 08:20 AM
