97 psd compression test specs
Old Jun 11, 2013 | 08:31 PM
MONAVIERONJON's Avatar
MONAVIERONJON
got me a 200k mile engine for $300 complete along with the instrument cluster. truck was inoperable so went ahead and swapped instrument cluster into my truck to verify mileage @ 209,952. Just did a compression test and all cylinders are at or near 300psi. this is a bone stock psd and wondering what the bottom line is for actual psi for a cylinder to mis fire/ Also should i install new injector o rings would there be a noticeable difference in compression psi? I've done cylinder o rings before and had not taken a before and after compression test. thankx!
Old Jun 11, 2013 | 09:37 PM
ReBilld's Avatar
ReBilld
Is the engine in your truck now? If so did you do the compression test on the engine while hot and with all 8 glow plugs removed? The compression on a cold engine will be higher than it actually is.
Old Jun 11, 2013 | 10:45 PM
MONAVIERONJON
trans and starter were already sold, so a cold compression test with gp's in has been performed after purchase. This is a complete motor sothe purchase was mainly for the fuel bowl, turbo, oil cooler and potential for rebuild on the block at a later date
Old Jun 11, 2013 | 10:54 PM
ReBilld's Avatar
ReBilld
I hear ya! I just picked up a '95 7.3 out of an ambulance. Plan on a rebuild on it someday, maybe just to sell.
Old Jun 12, 2013 | 01:24 AM
richdawg's Avatar
richdawg
Bill why would it be higher when cold? I thought it would be just the opposite
Old Jun 12, 2013 | 09:00 AM
MONAVIERONJON
oil has more viscosity and thins when warmed up from operation. The gp's are removed to make it a little easier to turn the motor over for the testing process
therigwelder
Dec 30, 2016 08:56 AM
jmadsen
Flathead V8 & Flathead 6
Jul 16, 2008 06:08 PM
BENG0924
17
Apr 13, 2008 07:13 AM
rowdie-stang
1997 - 2003 F150
Feb 17, 2006 10:34 PM
jopey
1978 - 1996 Big Bronco
Feb 1, 2001 06:00 PM
