what size socket?
Old Jun 11, 2013 | 04:01 PM
e6ug's Avatar
e6ug
what size socket?
what size socket will i need to Remove the large nuts holding the rear of the radius arms to the frame brackets on a 76 f150.
Thanks for any help
Old Jun 11, 2013 | 05:32 PM
Bradslab's Avatar
Bradslab
1 1/8 Are you taking the radius arm off entirely?
Old Jun 11, 2013 | 05:40 PM
jim collins's Avatar
jim collins
I second that , 1 1/8 self locking on the 79s i removed to put on my 73 which look to be the same size with the nut that uses a cotter key. Same end wrench will remove nuts on the bolt that holds the front to the axle . I'm removing all of the 73 f-100 front and replacing with 79 F-150 parts .
Old Jun 11, 2013 | 05:57 PM
e6ug's Avatar
e6ug
Thanks.
i am pulling the whole front end for a disc brake swap.
its a 2 hr drive to the parts truck, just want to make sure i have all the right tools to get it dropped.
Old Jun 11, 2013 | 06:30 PM
jim collins
I believe i used a 9/16 wrench to remove the small clamp at the top of the coil springs to release them from the spring top cap. Shocks may be 5/8 and 9/16 , i don't remember. Take a wire brush and lot's of panther XXXX.
I was thinking 76 came with disc ? My 73 has them . Is it 2 wheel or 4 wheel drive ?
Old Jun 11, 2013 | 06:37 PM
Bradslab's Avatar
Bradslab
Bring a majority of your SAE size sockets, lots of lube, wire brush, a breaker bar and maybe a cheater bar to go on your breaker bar.
Old Jun 11, 2013 | 07:31 PM
e6ug's Avatar
e6ug
Thanks for all the help
i am pulling the 76 front end for my 69 ranger
think i have all the tools i need besides that big 1 1/8
Old Jun 12, 2013 | 05:58 AM
jim collins
Hope I'm not to late to tell you the socket i had was not a deep one and would not work , so i ran in to the parts store ,NAPA, and bought a combination box end open end wrench. Sorry i forgot to say i had to do that.
Old Jun 12, 2013 | 09:56 AM
e6ug's Avatar
e6ug
thanks for the info. looks like i am not going to get it till next week.
can i ask what you paid? this guy is going to charge me $300 for the front end and all the brake parts+ steering gear pitman arm. am i overpaying?
Old Jun 12, 2013 | 12:27 PM
jim collins
I already had the complete front from one of my old 79 super cabs i scraped out. So i really don't know what they are worth. The reason i am changing mine over is the 73 never came with a good stabilizer bar and the 79 i have has it along with the heavy duty progressive front coils . They could be ordered with the 460 , made from thicker wire stock i guess is the right term to use.
I'm thinking the $300.00 is within reason since you are getting everything from the steering column joint to the ground . He should include the springs and shocks too even if you don't need them.
Old Jun 21, 2013 | 10:29 PM
e6ug's Avatar
e6ug
was a lot easier than i thought it would be. the proportioning valve attached to the steering gear. i thought they were located on the frame? i snagged the steering gear anyways i planned on replacing most the parts with new, but this thing is in really good shape. might just clean it up and slap it on.
mean351stang
Aug 10, 2023 06:04 PM
Mustangking1
Dec 4, 2014 07:07 PM
RJCarp2
Jun 15, 2007 09:46 AM
Donald Rohret
1983 - 2012 Ranger & B-Series
May 21, 2004 06:15 PM
