I said check the rubber lines... that will account for alot of the spongyness. Make sure your right rear bleeder isnt plugged. I guess have someone hit the pedal and see if you get anything.
don't give up.sometimes you just have to start over.
start with bench bleeding the master again.this time do it for much longer.give it 50-100 pumps or something stupid crazy then bleed at the wheels starting with longest runs of brake lines first.give each wheel like 10 full pedal stokes after you don't see any more air bubbles.make each wheel count overkill.you'll get 'er.
