Leaf Spring Suggestions
Old Nov 28, 2018 | 07:09 PM
bsr99's Avatar
bsr99
1997 F250HD
7.3L
4x4
No lift
Front is 4600GVW
Rear is 6084GVW
Need new leaf springs for the front. Most likely replacing the rear as well along with the shocks. All of the springs I am finding online don't support the weight. Any help is appreciated.
Largest trailer is a 14,000lb 33' gooseneck horse trailer.
Old Nov 29, 2018 | 08:07 AM
Jarrett Campbell's Avatar
Jarrett Campbell
This is where I got springs when I did my RSK.
https://www.autoandtrucksprings.com/
Old Nov 29, 2018 | 08:21 AM
farmert's Avatar
farmert
https://www.sdtrucksprings.com/index...8196&x=69&y=15
Try the above link. The springs are rated per spring, so take the capacity of the spring X2 for you application. You can get the spring code on the tag on the drivers side door jam, and check by the code for the correct spring. I have purchased springs from these guys and was really pleased with their service. If you are not sure which ones you need give them a call
Old Nov 29, 2018 | 08:22 AM
knottyrope's Avatar
knottyrope
look at 96 springs since 97 is wrong in most parts books
do you have TTB or a D60 front end?
VaFordman26
Nov 9, 2017 06:30 AM
LittleBlue79
Mar 26, 2017 07:00 AM
DeathRangerofDeath
Mar 5, 2016 04:58 PM
comadvan
Mar 6, 2011 09:09 PM
brokenpaw
May 27, 2010 08:34 AM
