Explain Engine Power To Me
Old Jun 11, 2013 | 12:57 PM
SoManyFords's Avatar
SoManyFords
I have a 1967 F100 Ranger. It has a 351C 2V out of a 1973 Torino in it. I am in the process of restoring the truck. I am inclined to stick with the 351C, but do I get aluminum heads? Do I do a Stroker? Do I just do a standard rebuild? What do those things do for me?
I would like it to be able to do some burn outs, but I am not racing it. I would like to occasionally drive it about town, but it won't be my everyday driver.
Old Jun 11, 2013 | 01:29 PM
390POWER's Avatar
390POWER
what is your target horsepower? what is your budget? a slightly over stock 351 can roast the tires if thats all you want to do. but we need more info, what trans would also help
Old Jun 11, 2013 | 02:08 PM
SoManyFords
Automatic transmission. I don't know my target horsepower. I am looking for suggestions. I don't want to put $5K in the engine, but I might do $3K. I can get my existing engine rebuild with steel heads, stock cam for $1400. I found a crate engine on line for $3200 steel heads - performance cam. Then they seem to jump to $6K or 8K.
Old Jun 11, 2013 | 02:57 PM
390POWER's Avatar
390POWER
I would skip the heads for now, put money into making it breath better, intake, carb, headers, and cam. a msd would also be money well spent, if you are doing a complete rebuild better pistons will also help
Old Jun 11, 2013 | 03:46 PM
SoManyFords
What is msd?
Old Jun 11, 2013 | 04:28 PM
MIKES 68 F100's Avatar
MIKES 68 F100
Brand MSD ignition , distributers , coils ...etc
Old Jun 11, 2013 | 04:49 PM
elgemcdlf's Avatar
elgemcdlf
Given how you present yourself knowledge wise I would not mess with the engine if I were you. If you need to replace the engine then do a stock rebuilt off the shelf (long block) & work at it little by little as you begin to understand more about how engines work. I would highly recommend The Visible V8 model. Buy it & assemble it. When finished it will rotate like a real engine & you can watch how all the parts interact with each other.
When you are ready start with basics. Headers & a decent exhaust. Then maybe an aluminum intake & carb. Do some dress up items to make it pretty. This step will also help you become more familiar with the engine parts. I am not trying to bust your ***** or anything here. You sound very inexperienced with engines so I think it might be best to stick with stock (easier to diagnose issues) until you get a bit of knowledge under your belt.
Old Jun 11, 2013 | 05:41 PM
bradb2230's Avatar
bradb2230
I agree completely. There are so many different things that have to be matched to each other. It all starts with deciding what is more important to you. Is it horsepower or torque. High RPMs or low RPM? Where in the RPM band do you want your HP? Same goes with torque. Someone that wants to pull 10 second quarters, will have LOT of HP and high RPMs. Building a pulling truck requires let horsepower, lower RPMs, but Lots of torque. Your torque converter needs to be matched to your power band. your rear axle needs to be capable of handling the power your giving it.
wakeboarder32
Jan 9, 2011 04:22 PM
reed1951
15
Nov 5, 2010 12:14 PM
move
Dec 9, 2004 08:39 PM
Texan1983
Jun 27, 2003 10:59 PM
Finnford
Apr 10, 2003 09:00 AM
