Engine build
Old Jun 27, 2003 | 08:17 PM
Texan1983's Avatar
Texan1983
Engine build
i have one question, what whould you recomend i put on my 77 400m? i have a 750holley, intake, and headers. currently i have a rebuild planned next week, i want some more power, what heads should i buy? i don't want outraguos compretion. needs to be dailly driving right now. what heads and where can i get them please, thanks
Texan1983's Avatar
Texan1983
Engine build
oh yea i will be adding a cam with the rebuild
Old Jun 27, 2003 | 09:15 PM
Torque1st's Avatar
Torque1st
Posting Legend
Engine build
Your carb is too big, try a 600/650.
Cam: 255/265 or 260/270 Max adv duration. Always use a dual pattern.
Heads: Use your stock heads and do a little blending in the valve pockets. Do NOT gasket match the ports.
Old Jun 27, 2003 | 09:27 PM
Texan1983's Avatar
Texan1983
Engine build
my stock heads will work ok? anything flow higher?
Old Jun 27, 2003 | 09:40 PM
Torque1st's Avatar
Torque1st
Posting Legend
Engine build
Yes, but not by much, and you don't need it for a daily driver. Too much flow capacity will hurt your bottom end.
Old Jun 27, 2003 | 09:47 PM
Texan1983's Avatar
Texan1983
Engine build
alright, any one know how well those holley off-raod carbs work? i was looking at getting a 670
Old Jun 27, 2003 | 10:59 PM
Torque1st's Avatar
Torque1st
Posting Legend
Engine build
Thread split from Aussie Head topic.
Texan, turn ON your email! Other users do not have access to your address, only the system knows your address.
There are other threads in the Carb and fuel systems forum about that carb and others. Search for the info if you want to know fast or post your question there.
