vacuum line sizes
Old Jun 11, 2013 | 01:15 AM
wr310rdr's Avatar
wr310rdr
vacuum line sizes
can anyone give me a run down on the sizes of vac line in a 92 f250 460 4x4 5speed?
I bought the truck and am going through it to make it driveable, I know it has multiple leaks and with the amount of miles and the condition its all in I would rather replace it all then hunt and peck for leaks.
I plan on getting 10+ feet of the sizes and cutting it to size the only line that has size marked on it is the brake booster everything else either had no markings or is degraded beyond the point of reading it.
Old Jun 11, 2013 | 08:49 AM
UNTAMND's Avatar
UNTAMND
If you're replacing it, just cut a piece off and take it with you to match up.
The plastic line you can do the same thing with.
Old Jun 11, 2013 | 03:42 PM
Rop3r's Avatar
Rop3r
Here you go good write up on it. Just did mine on Sunday in about 1hr 15mins real simple and not frustrating. Plus you can get rid of almost all the plastic tubing. I used the silicone hose. So far it is doing fine. Was worried about one of them because it was so close to the manifold but it has not been fazed. I also went to the auto store and got some wire loom the help protect it though.
Replace Plastic Vacuum Hoses with Rubber - FSB Forums
Old Jun 11, 2013 | 03:43 PM
Rop3r's Avatar
Rop3r
Only thing its a write up for 300, 302, and 351, but it'd get you going in the right direction.
jimbo285
1978 - 1996 Big Bronco
Mar 22, 2016 05:35 PM
87oldtimer
Jun 3, 2014 06:02 PM
pittmick
1997 - 2003 F150
Sep 13, 2011 09:19 AM
jadmt
Dec 8, 2007 02:41 PM
fcarruth
Dec 13, 2002 06:37 PM
