94' in a 90'
on
One other thing, the '94 motor has a roller cam while the '90 had a flat tappet so you will need to swap drive gears on the distributors.. steel roller cam needs a steel gear while the cast flat tappet cam needs to see a cast drive gear, mix them up and the softer gear will wear out very quickly and ruin the motor. These gears are pressed on so you'll need a gear puller to remove them and a socket and hammer to reinstall.. not a hard job I have done it numerous times.
Also you can't just swap distributors because they are wired differently, your '90 has the TFI module on the side while the '94 was setup for a remote TFI module.
1990-f250
07-09-2013 08:26 PM
fly4fun35
01-19-2005 04:14 PM
