Just ranting
Old Jun 11, 2013 | 12:01 AM
wtroger's Avatar
wtroger
Just ranting
I just did the plugs on an 02 expy this the third one I have done in the last 2 years. And I hope the engineer that designed this spark plug systems gets to spend eternity in hades changing plugs in these vehicles. These things suck when it comes to plug changes.
Old Jun 11, 2013 | 10:48 AM
r2millers's Avatar
r2millers
If it weren't for the back two, Especially on the passenger side #4, it really isn't that bad once you take several deep breaths, have the right tools, duct tape to keep the socket and extensions together, lay a mat down on top of the engine, tie off all the heater hose/vacuum stuff, etc.
Fortunately from experience, you know what you're getting into again. At least you don't have the 2 piece plugs to create more havoc.
Old Jun 11, 2013 | 10:31 PM
wtroger's Avatar
wtroger
Yep you are right you basically have to get in bed with it and have a boat load of swivels and assorted extension lengths to get these plugs changed. Actually number 7 on drivers side was a pain they put the fuel pressure regulator over the coil hold down bolt. And I have turned down a couple of plug changes on 3 valve engines because of the 2 piece plug issue.
Old Jun 12, 2013 | 12:25 AM
alloro's Avatar
alloro
The 4-valve engines like in the Navigator are much easier to do. Well, except for #8 where they decided to run the EGR tube right over the COP.
SoCalAngler
Modular V10 (6.8l)
33
Jun 13, 2017 12:43 AM
UrbanXX
Jun 2, 2010 03:29 PM
mmorto
4 Cylinder Engines
Apr 3, 2009 07:06 PM
Aeroman59
Aerostar
21
Oct 17, 2008 07:11 PM
CD1
1997 - 2003 F150
Nov 12, 2006 08:57 PM
