I have a 91 F150 4x4 351 E4OD. Last night on my way home from a friends in the country my truck suddenly accelerated while I was doing about 55mph. It only did it for a few seconds but is still very concerning and this happened two times on the trip home. On the way out to my friends it did the opposite with just a light stalling but only one time. Does anybody have an idea of where I should even start to figure this problem out?
There's a chance it has so something to do with the TPS so pull the codes first and make repairs if necessary, but if that comes up clear then start looking for mechanical things like a sticking throttle cable or heavily warn throttle linkage on the TB.
No the cruise control was not on. Now that I think about it bout a year ago I was driving with it on and it did accelerate once so I just quit using it. Could this be the cause if it wasn't even on?
Doubtful but you can just disconnect the cable from the C/C unit where it attaches to the throttle if you want to eliminate that as a possibility.
Ran codes today came up with 13 and 72. Does anybody know what these are and if they could lead to my problem?
Those are Codes from the Key On Engine Running tests, which are operator induced. You should start with the Key On Engine Off (KOEO) tests and Continuous Memory (CM) display.
