5.4 3v plug electrode removal
Old Jun 9, 2013 | 09:50 PM
Ford4me302's Avatar
Ford4me302
I am currently working on a 2004 f150 5.4 3 valve trying to change spark plugs I have done this a few times in past but have never encountered this much trouble and by the way I have done a lot of thread searching and no one has anything about this
So after much soaking in carb cleaner for days working plugs slowly all I can get out is the upper nut part of plug the rest of plug remains and on the first one trying to pull the top porcelain piece and electrode out all I got was the top portion and the electrode broke off flush with Lower porcelain so I then used the removal tool by pushing porcelain down to get tap in pulled the rest of it out and by doing so it had broke the electrode strap off tip of plug and left it in cylinder so with many hours of bore scope fishing I got it out but I am now working on the next plug and I am having the same trouble it's like the tip of the electrode is carbon'd up so bad that it won't come through lower porcelain piece u can't pull hard enough with needle nose pliers to get it to come out if u could in some way maybe hook a slide hammer to end of it I think it would come but I can't seem to figure out how to do so the truck has 140,000 miles on the original plug and I'm guessin that is the reason I am having so much trouble with this one anyone have any ideas I really don't want to go fishing anymore thanks
Borgia
Aug 7, 2017 04:48 PM
bassinbick
1997 - 2003 F150
Dec 9, 2016 08:13 AM
kramerpage
2004 - 2008 F150
Feb 8, 2015 08:16 PM
hans2112
Aug 5, 2012 08:16 AM
FoxNotch
Mar 19, 2012 04:13 PM
