Ball joint installation
Old Jun 9, 2013 | 09:26 PM
Wyowanderer's Avatar
Wyowanderer
This pretty much works for all vehicles that have ball joints.
When you're ready to install the ball joints on your axle, especially the uppers, install the grease fitting into the ball joint FIRST, then mark the direction the fitting is pointing with a permanent marker. Then remove the grease fitting, and install the ball joint with the mark pointing the direction you'd like to grease it. That way it'll be installed the right way, without having to overtighten or leave it looser than you'd like.
Old Jun 10, 2013 | 09:45 AM
Franklin2's Avatar
Franklin2
That may or may not work on these trucks. When the alignment guy goes to turn the eccentric around the joint, The joint might move with the eccentric, messing up which way your grease fitting is pointing.
Old Jun 11, 2013 | 12:18 PM
Social_Joe's Avatar
Social_Joe
The eccentric goes around the stem of the ball-joint, the grease zerk is in the cup of the ball-joint and is pressed into the traction beam. So I don't see how an alignment tech rotating the eccentric could possibly move the cup and the grease zerk that screws into it.
Good idea, OP.
Old Jun 11, 2013 | 03:12 PM
Franklin2's Avatar
Franklin2
Your right, sorry about that.
Old Jun 11, 2013 | 10:04 PM
JPalmer81's Avatar
JPalmer81
I just did my balljoints and I was able to line up the zerks for easy accessibility and press them in with the zerks installed and pointed in the right direction. easy peasy
Keny1
Mar 18, 2014 06:13 AM
bigb56
Oct 18, 2013 04:41 PM
baitbucket
Jan 22, 2009 10:26 PM
woody367
Sep 11, 2008 01:19 PM
m@m
2004 - 2008 F150
Dec 8, 2007 08:41 PM
