Sponsored by: Auxito
Overheating
Old Jun 9, 2013 | 12:13 PM
Tartuga's Avatar
Tartuga
Overheating
I am having a problem with the clutch fan not coming on at high temps pulling a grade or flat. Replaced the clutch had the front of the radiator removed and all the debris blown out and replaced the thermostat. Still over heating and the fan comes on real late.
Old Jun 9, 2013 | 02:53 PM
Bluegrass 7's Avatar
Bluegrass 7
Have you considered the radiator could be partially plugged in it's lower section reducing it cooling capacity.
It may cool under light load but overheat under heavier loads.
It may be the cap has failed, as well.
Good luck.
Ryan9969
1997 - 2003 F150
Jul 24, 2010 08:06 AM
Flashman
May 9, 2010 11:21 AM
smileyoppossum
Jun 16, 2009 07:31 PM
fizzdive
May 23, 2005 05:45 PM
michaeld6638
15
Sep 2, 2003 08:11 PM
