Sponsored by: Auxito
00 5.4L overheating
Old Jul 23, 2010 | 10:05 PM
Ryan9969's Avatar
Ryan9969
00 5.4L overheating
my 2000 f150 5.4 is overheating when it idles for more than 5 mins, usually its when the temp is more than 90 degs F. Right before it starts to overheat is starts idiling alittle rough. Then when I go it cools right down, radiator? Fan? Any help woiuld be great thanks!
Old Jul 23, 2010 | 10:22 PM
Bluegrass 7's Avatar
Bluegrass 7
Is the fan clutch working normal?
Is the coolant level high enough?
Is the coolant bottle cap good?
Is the thermostat faulty?
Is the radiator bottom part plugged?
I would service all these areas and pay special; attention to the radiator being restricted.
Why, because you say it cools when you drive.
That indicates extra air is required to cool the restricted cooling area.
It would only get worse with time.
Good luck.
Old Jul 23, 2010 | 10:40 PM
Ryan9969's Avatar
Ryan9969
how do I check the Fan clutch?
Old Jul 23, 2010 | 11:32 PM
Bluegrass 7
Fan clutch is thermally controlled.
Either it free wheels or is bound up and runs at all speeds.
In between these, you would have to force it by hand, slipping the clutch
A way to check for thermal operation is to connect a good 'clamp-on' timing light to one of the cylinders fuel injector's or coil cables allowing it to trigger the light.
With the motor running and heated, aim the light at the rotating fan blades.
As the fan clutch engages and disengages per the coolant temp changes the clutch senses, the fan blades will stobe to make them stand still then go out of strobe as the radiator temp changes via the thermostat operation.
You can see both these actions by proxiy and see if there is an issue to be addressed.
Try draining the radiator. If it is hard to get it to start draining, you most likely have a plugged condition.
Good luck.
Old Jul 24, 2010 | 08:06 AM
steve(ill)'s Avatar
steve(ill)
fan should turn fairly easy when cold, and when motor is "hot", shut off and try to trun the fan... should have a lot of drag.. Best guess, is just put a new fan on it, if the radiator fins are clean and you can see thru it. IF you just speed the motor up to 1200 RPM setting still, does it start to cool ?
cjblue
Jan 17, 2023 08:45 AM
Sheila Butts
Modular V8 (4.6L, 5.4L)
Nov 2, 2015 08:17 PM
hogheaven
Jun 25, 2015 02:29 PM
fred_79f250
Dec 1, 2013 05:07 PM
mreilly24
Arizona Chapter
May 2, 2011 11:30 PM
