FICM numbers
Old Jun 9, 2013 | 11:51 AM
snorindad's Avatar
snorindad
FICM numbers
I have and Edge CTS for two years now and the ficm voltage has always stayed between 47.5 and48.5. Over the last two weeks it is occasionally dropping as low as 46. Thebattery reads between 13.0 and 13.3. No codes. Is this an indication my ficm isstarting to go south? Thanks<o></o>
Old Jun 9, 2013 | 11:59 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Not yet, but you want the voltage to be 13.5+ at the OBD port, preferably seeing 14+ at all times.
Upgrade the stock alternator.
Josh
Old Jun 9, 2013 | 12:18 PM
snorindad's Avatar
snorindad
I have read about the dc power alternators on here and they seem like the way to go the cheapest one is 185 amp and is 300 the 270 amp is more than double that. What is the amp rating of the stock one. I replaced it only two years and 15k miles ago. Seems it should last longer than that. I am not running and extra electrical devices or lights just stock.
Old Jun 9, 2013 | 12:21 PM
Bullitt390's Avatar
Bullitt390
There are a lot of options for a higher amp alternator. Basically anything is better than the stock 110 amp unit.
I personally retrofitted a 3G alternator.
My choice for an aftermarket unit would be a Tenney or Mechman unit.
Josh
Old Jun 9, 2013 | 12:32 PM
snorindad's Avatar
snorindad
Do you have to upgrade any to the wiring when installing a higher amp alternator?
Old Jun 9, 2013 | 01:18 PM
Bullitt390's Avatar
Bullitt390
I wouldn't blink adding larger cables for anything over 200 amps.
Josh
MiamiPSD
39
Jul 22, 2014 01:33 PM
v_dub_1988
1997 - 2003 F150
Dec 29, 2008 07:44 AM
Lance Hogan
Apr 14, 2008 02:54 AM
Mazda_man
1983 - 2012 Ranger & B-Series
Nov 8, 2004 10:27 PM
