It is done....
Old Jun 8, 2013 | 08:59 PM
NMB2's Avatar
NMB2
It is done....
so I know a few people already knew, but I figured I'd let everyone know. I am finally done playing with IDI's, at least my own. I am finally gearing up for a re-power, for real this time.
Came home with this yesterday:
My Trans and Auto conversion parts (column, pedal box, floor plate, wiring) will be here on Tuesday thanks to HJ Liggenstoffer, not sure if he is a member on here, but he is a member on the facebook IDI page, can't thank you enough for the sweet hook up.
My fuel system in its entirety is already gone. IP, Injectors, lines, lift pump, regulator, ect...... still have pretty much everything else left and will be sold other than the shortblock/rotating assembly, minus cam.
Old Jun 8, 2013 | 09:00 PM
91dirtydiesel's Avatar
91dirtydiesel
Doooooooomed
Old Jun 8, 2013 | 09:08 PM
NMB2's Avatar
NMB2
Originally Posted by 91dirtydiesel
Doooooooomed
Basically.
Old Jun 8, 2013 | 09:30 PM
racer30's Avatar
racer30
What Turbo is on your new Engine now?.. Will you be doing some mods? To your new engine right away?
Old Jun 8, 2013 | 09:51 PM
kc0stp's Avatar
kc0stp
Just make sure you post pictures of your planned cover when you get it on, all the Ford fanboys will be more forgiving then
That said good luck getting the conversion done in a timely and cost effective manner (although no slacking we still need to go wheeling eventually )
Old Jun 8, 2013 | 10:15 PM
Ford F834's Avatar
Ford F834
Pardon my ignorance, but what, exactly, are we looking at? Cummins obviously but what is it?
Old Jun 8, 2013 | 10:36 PM
kc0stp's Avatar
kc0stp
NMB2s new engine, more specifically a mechanical 12valve Cummins out of a 97 Dodge think from the factory they had roughly 216hp and based on experience with NMB2 itll have just a tad bit more then that when its all said and done... (say around 550whp...)
Old Jun 8, 2013 | 11:02 PM
turtlemann14's Avatar
turtlemann14
i think you should try and stuff two of them in there...
i bet you would have the only v12 1500hp cumins powered ford.
Old Jun 8, 2013 | 11:26 PM
NMB2's Avatar
NMB2
thats just the stock HX35, its in good shape, so I'll sell it.
I'll be running an HE351/S475 compound set.
its a 1996 12 valve cummins.
Old Jun 9, 2013 | 12:16 AM
RacinNdrummin's Avatar
RacinNdrummin
So is this a build thread, or what br0?
Old Jun 9, 2013 | 12:19 AM
NMB2's Avatar
NMB2
could be......
Old Jun 9, 2013 | 12:44 AM
racer30's Avatar
racer30
YA... Get The build party Started...
Old Jun 9, 2013 | 01:06 AM
hairyboxnoogle's Avatar
hairyboxnoogle
Im sorry, this is the IDI forum, the loser forum is over there -->
lolz
Old Jun 9, 2013 | 06:09 PM
1964f250cummins's Avatar
1964f250cummins
If there is any thing else I can do let me know my friend
Old Jun 10, 2013 | 01:02 PM
86f250XLT-4x4's Avatar
86f250XLT-4x4
I still am wanting a turbo setup from you! Sometime anyway... Hopefully sooner than later
