400 Roller Rocker issues
Hey all,
I also posted this in the 335 forum, but there's more traffic here so I posted here too.
Recently had a 400 machined by TMeyer Inc.
I'm currently running into an issue when shimming it, at .80 I'm still quite a bit off a good pattern. I am using an adjustable pushrod set at the proper preload
I have to shim it to .160 to get a nice pattern on the tip, but by then I have completely lost the pedestal.
I'm thinking the heads have been machined too much, causing the valve to come up and now I'm having to compensate a ton with shims. I have .020 and .040 shims.
Here is no shims on #1 intake
I'll post more pictures of different shim combinations. If needed
NOTE: I've been doing the tip sweep with proper lifter preload, should I bottom out the lifter (I have adjustable pushrods I've been using) to simulate it being pumped up and get the true tip sweep?
79f1dy
02-21-2016 02:17 PM
wyckedcombo17
07-06-2013 10:00 PM
5.0stang
09-19-2007 11:04 AM
