BRAKING ISSUE
Old Jun 7, 2013 | 05:18 PM
doodoohead's Avatar
doodoohead
BRAKING ISSUE
Hello Gentleman and Ladies as well,
2005 F350 Lariat Crew Cab Shortbox Superduty 6.0 Powerstroke Diesel
When i depress the brake it feels like a thump thump thump thump...
Is that a caliper or a rotor? Or is that stupidly not enough info?
I can feel it in the pedal as well, at real slow speed it feels like catch release, catch release, catch release.....
Will a bad caliper cause that effect?
Any thoughts are appreciated, thank you.
Old Jun 7, 2013 | 05:33 PM
69cj's Avatar
69cj
Sounds more like a warped rotor than a caliper problem. You might also check that all the hardware is tight.
Old Jun 7, 2013 | 06:15 PM
GB73's Avatar
GB73
X2 on the rotors
Whenever I let my trucks sit for longer than a couple of weeks I get that with the brakes...especially if it rained. It usually clears up on its own after a few brake applications. However, I had a truck sit for six months and I had to replace pads and rotors to get rid of the pulsating brake pedal.
Old Jun 7, 2013 | 06:50 PM
doodoohead's Avatar
doodoohead
Thank you 69cj and GB73
I shall check those first, much appreciated.
Old Jun 8, 2013 | 06:53 AM
fmtrvt's Avatar
fmtrvt
When a vehicle sits, especially outside, it takes along time for moisture to evaporate between the few thousands of an inch gap between the rotors and pads. An iron oxide growth of less then 0,001" is all you need to develop pulsation when braking; Iron oxide is a hard material and can take some time before it is worn away unless you have a friction material compound with a high metallic, abrasive nature.
"Warped" is a bad term to use as rotors with runout do not cause pulsation unless the calipers cannot more laterally with the runout. Thickness variation in the rotors, from oxidation in this case or wear of the high runout areas of the rotor will cause pulsation.
Tires that are starting to separate will also cause pulsation when braking, and often you can see or feel the issue when going very slow without braking with intermittent twitching of the steering wheel.
fordmustangfan67
Aug 3, 2015 08:54 PM
FordTruckEnthusaist
Mar 25, 2013 04:13 PM
bekko
Mar 16, 2008 12:03 PM
Haymanwolf
Dec 26, 2007 01:07 PM
amm888
General Automotive Discussion
Dec 4, 2006 09:51 AM
