Remove bed trim
Old Jun 6, 2013 | 03:14 PM
MackGuy's Avatar
MackGuy
Remove bed trim
Hi all,
I have a 1990 F250 custom... somewhere along the way the bed was swapped, and the "new" bed has a little trim strip on it that the cab doesn't have, as shown in the picture (also two different colors of white). I'd like to at least remove the trim strip. Is this glued on or fastened or how can it be removed?
Thanks,
Old Jun 6, 2013 | 04:33 PM
Diesel_Brad's Avatar
Diesel_Brad
Double sided tape. You can pull it off or take heavy fishing line and "saw" thru the tape. Either way you will be left with the remainder of the tape
Old Jun 6, 2013 | 06:28 PM
MackGuy's Avatar
MackGuy
Thanks, I should be able to get the other half off with some elbow grease and goof off... Should be better than having the mismatched trim.
Old Jun 6, 2013 | 08:48 PM
f1504x4driver's Avatar
f1504x4driver
Proud Pirate
you can buy and eraser wheel at your local body shop supply. It fits a drill or cordless and will take off pinstripe or the glue under the molding with ease and will not damage the paint.
460harris
Sep 5, 2019 03:22 PM
Vice1391
Jan 2, 2017 11:34 AM
mjr46
May 4, 2016 05:32 PM
4x484150
Jun 2, 2012 08:17 AM
Redneck1465
Jan 22, 2012 08:56 PM
