1999 Explorer XLT V6 SOHC Brake Problem
I noticed today that my brakes drop nearly to the floor when I press on them. The car just passed inspection so I doubt that they brakes are worn. Master Cylinder has the correct level of fluid and the pedal is hard when the vehicle is off, so I doubt that the master cylinder is failing.
How would I go about troubleshooting this problem?
The rear brake line was corroded and had a hole in it. I have spent now 13 hours trying to install a new line that doesn't leak at the fittings and am SOOO frustrated! It seems that no matter what I do I get a leak under pressure. I would use the ones that have been pre-installed on the line at the auto parts store, but the fittings they have do not seem to work in the car - they are too large. I got an OEM double flaring kit from autozone, but that chinese junk can't seem to make a good end.
Open to suggestion.
Open to suggestion.
timbersteel
04-25-2016 11:11 PM
joemajesty
07-28-2010 04:12 PM
