Engine Identification
Old Jun 5, 2013 | 10:07 PM
rsirrin's Avatar
rsirrin
Hey guys, sorry I'm new at this but I have a '72 F250 crew cab with a 390 V8 that I have to rebuild. If its the original engine I need to keep it in the truck because its a rare truck but I don't know how to tell if its the original... Any help would be greatly appreciated.
Old Jun 5, 2013 | 10:23 PM
HIO Silver's Avatar
HIO Silver
"Rare"? Are ya referring to the crewcab itself or the engine? What is your criteria???
You really won't be able to tell if it is truly original because Ford, with very few exceptions like the K-code Mustangs and a few others, never stamped VINs on engine blocks.
The best you will be able to determine if it is "period correct" through casting/engineering numbers on the various parts and pieces. Sometimes it can be further reasonable deduced if it uses a rope seal at the rear main, original exhaust manifold bolts and washers (they usually get lost or replaced with incorrect hardware), and other hardware that appears like they have never been turned since it rolled off the assembly line. Even then, the results are based on an educated guess.
Btw, 360FEs become a 390FE when vehicles are put up for sale. You'll need to do the dowel measuring trick at BDC and TDC through a spark plug hole. A 360 will be like 3.50 inches and a 390 at 3.75 inches or so.
Old Jun 5, 2013 | 11:18 PM
rsirrin's Avatar
rsirrin
I say rare because of my build sheet. It shows 1 of 900 with my trim code. Most of them built that year were long beds and 4-speeds for city and railroad crews. Mine is a 390, short bed, factory dual tanks, front discs, factory air, factory dual tanks
Old Jun 5, 2013 | 11:38 PM
HIO Silver's Avatar
HIO Silver
OK I dig it. Based on configuration then yes, but I'd use the term "unique".... Rarity in the hobby is generally attributable to production numbers but there were likely a few thousand crews produced. By the number of today's survivors then there are likely not many still on the road.
So, how many shortbed F250 crews were produced in '72?
Old Jun 6, 2013 | 06:23 AM
rsirrin's Avatar
rsirrin
My build sheet just says with trim code it's 1 of 905 of only 2,564 crew cabs ordered that year
Old Jun 6, 2013 | 08:58 AM
MIKES 68 F100's Avatar
MIKES 68 F100
like others said , Ford didn't " number match" their vins to engines and such on most of their vehicles , so all you can do is make sure your engine is date coded correctly for the build date of your truck .
Old Jun 6, 2013 | 12:07 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by MIKES 68 F100
So all you can do is make sure your engine is date coded correctly for the build date of your truck .
How can a date code cast on an engine block relate to the assembly date of a vehicle?
Engine block cast, then placed outside to season, then shipped to engine plant to be finished.
Completed engine shipped to assembly plant where it is banked until required.
So, from the foundry mark date code that the block was first cast, it could be between three months to a year before engine installed in vehicle!
1970: First use of Safety Standards Certification Label. Has the production date printed on it.
b17goinmyway
19
Sep 20, 2007 09:37 AM
grandads76
May 24, 2007 01:56 AM
joeddavis
Jun 23, 2006 05:00 PM
suecque
Feb 13, 2005 09:57 AM
75HighboyF250
Oct 19, 2003 05:18 PM
