front leaf springs?
Old Jun 5, 2013 | 08:29 PM
Stolher's Avatar
Stolher
front leaf springs?
Hey all, New here. Trying to figure out if my front leafs are factory or not. I assume so but they look extremely weak for a 9k rig. Ive been searching but I have not come across anything that specifically answered my question
Thanks all
pictures
Old Jun 5, 2013 | 08:35 PM
housedad's Avatar
housedad
negative arch, two leaves, jounce bumper cut off to provide clearance for sagging springs... I'd say, yep. those are C code OEM original springs. Worn out.
Looks like time for B's and V's.
Old Jun 5, 2013 | 08:51 PM
Stolher's Avatar
Stolher
Thanks I suspected so. Another question I have not seen answered, Can I do just the V codes up front and leave the rear alone?
Old Jun 5, 2013 | 08:53 PM
housedad's Avatar
housedad
I makes the rear look like it is squatting. The rear ends up low. You can drive it like that and really have no ill effects.
The B's and blocks give a somewhat better ride though, and bring back the correct 1.5" back to front rake.
Old Jun 5, 2013 | 08:57 PM
Tom's Avatar
Tom
First off your Excursion isn't 9,000 lbs; it's closer to 7,800. And secondly if you ever look at the front springs of a Freightliner road tractor you'll also see a 2-leaf spring that doesn't look much beefier, and that's rated for 12,000 lbs axle weight! You can't judge a spring by the look.
And yup, looks factory to me! My V-codes left my front a good 1-1.5" higher than the rear, so you may be dissatisfied with the results. There are other options such as airbags for the front, and those are adjustable to provide the amount of support you're looking for.
Old Jun 5, 2013 | 09:11 PM
housedad's Avatar
housedad
That's 12000 lb per set for the Freightliner. 6000lb per spring.
V codes are 10,400 lbs per set, I believe. I could be wrong on that. 5200 lb per spring. X codes are 6000lb per spring.
Old Jun 5, 2013 | 09:16 PM
Tom's Avatar
Tom
V codes are 10,400 lbs per set. 5200 lb per spring. X codes are 6000lb per spring.
I don't think so. They're not even close. That's the combined rating at the ground, not the rate per spring. I'll post the spec sheet before I go to bed.
Old Jun 5, 2013 | 09:24 PM
housedad's Avatar
housedad
Found it. Excursion springs (Ccode)are 4300lb per set. I was wrong. So they rate them by the set for the excursions and Superduties..
Interesting.
Old Jun 5, 2013 | 10:56 PM
EXv10's Avatar
EXv10
Yep, those are stock and if they don't bottom out don't worry about it. If you put heavy springs in you will stiffen the ride.......not something I would want.
Old Jun 5, 2013 | 11:53 PM
rockcrawler_101's Avatar
rockcrawler_101
Your also missing your bump stop
Old Jun 6, 2013 | 12:11 AM
Stewart_H's Avatar
Stewart_H
Bion noticed that and mentioned it in post #2, too.
Stewart
Old Jun 6, 2013 | 12:17 AM
Kdr358's Avatar
Kdr358
Since it looks like you have the Diesel I would say so X codes if you plan on adding a large bumper setup. V codes will work just fine, I have X's in my Ex and the ride actually isn't as bad as everyone says. The X code is the Plow prep package springs from F250-F550 Gas or diesel. When I did my swap I did the front first the rear sat about 3-1/4 inches lower then the front.
Old Jun 6, 2013 | 12:29 AM
rockcrawler_101
Stewart
Yep didnt notice it sense i read it as jouncing ride. I Need to read better!
Old Jun 6, 2013 | 12:32 AM
Stewart_H's Avatar
Stewart_H
Just curious, but what did you see in the pics, that I missed, that leads you to believe he has a diesel?
Stewart
Old Jun 6, 2013 | 12:35 AM
Stewart_H's Avatar
Stewart_H
Hmmmm...unless....
Stewart
