mystery hole`
Old Jun 5, 2013 | 08:10 PM
jniolon's Avatar
jniolon
old and in the way
mystery hole`
there is a hole... looks to be stamped from Ford by the edges... in the cowl above the firewall..... wonder what went there ?????... do I need it ???>
later
john
Old Jun 5, 2013 | 08:35 PM
ranger pat's Avatar
ranger pat
Veteran: Navy
Is that the hole for the rods that connect between the firewall and the outboard edge of the radiator support cover? Is there another matching hole on the driver's side? It might be an alignment hole used to locate the welded on angle bracket that holds the rod against the firewall. Looks like the bracket has a small stamped hole that would fit in the hole in the firewall. If you don't plan on using the alignment rods, you sure don't need that hole.
Old Jun 5, 2013 | 08:36 PM
avf100's Avatar
avf100
Mine has one also...I could be wrong, but I think it is for the vacuum supply hose to the wiper motor. There is a grommet and the hose goes thru the grommet.
Old Jun 5, 2013 | 08:43 PM
bobj49f2's Avatar
bobj49f2
Weld it shut and you'll find out that you'll need it and what it is for.
Old Jun 5, 2013 | 08:47 PM
JWC 3's Avatar
JWC 3
This is not what i expected to see when I Googeld Mystery Hole ! ( sorry had to post that thought ) Don't kick my teeth out for being warped LOL ! Sorry , no good info , but the vac line seems good .
Old Jun 5, 2013 | 08:52 PM
jniolon's Avatar
jniolon
old and in the way
no pat, the support rods connected to a gusset plate under the lip of the firewall
vacuum hose access sounds probable.... I'm gonna disappear it...
thanks guys
john
Old Jun 5, 2013 | 09:27 PM
4tl8ford's Avatar
4tl8ford
You'll lose your AC
Old Jun 5, 2013 | 09:35 PM
CharlieLed's Avatar
CharlieLed
All the slant cabs have it but not the 56. Every one I have come across has had a metal plug in it. With all the patching you are doing on that firewall you may as well close it up.
Old Jun 5, 2013 | 10:16 PM
das54's Avatar
das54
I beg to differ with ya on this point. That's one hole I didn't fill and I still don't know what it is for.
Old Jun 5, 2013 | 10:32 PM
53 tonner's Avatar
53 tonner
I agree with this answer. That's what it's for on my '53.
Grant
Old Jun 6, 2013 | 11:02 AM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Whew, I'm glad someone else took this route and I didn't have to.....LOL
I was going to go with a reference to a girl I knew back in high school or something like that but thank goodness I don't have to go there now....dodged that bullet
Bobby
Old Jun 6, 2013 | 11:27 AM
Dobies4life's Avatar
Dobies4life
Fill it, then forget it!
Old Jun 6, 2013 | 11:33 AM
jniolon's Avatar
jniolon
old and in the way
Bobby... you're a sick demented reprobate !!!! THAT'S why I like you so much
j
Old Jun 6, 2013 | 07:47 PM
imabaka's Avatar
imabaka
Your not the only sick minded one here. My mind instantly went dirty when I read that title.
Old Jun 6, 2013 | 08:54 PM
topmoo's Avatar
topmoo
It is a great title, of course I had to open the thread to see...
