Common no one here has this center console here that could give me a couple measurements off of? I am looking to adapt this to my new interior of my truck if the measurements work with my seats. Thanks!
That's the console I have in my 06. It measures 29" front to back x 12-1/2" to 13" wide and 16" tall from the center of the transmission tunnel or 18" high on the sides. These dimensions are within +/- 1/4". I hope this helps you out.
Yes, it appears so. That's probably to fit the transmission tunnel better. It also generally follows the profile of the side of the seat. The cushion portion is wider than the track that it is mounted on. It helps give a smoother gap top to bottom. I really like this console. You can put a lot of stuff in there and the cup holders are positioned about perfect. I have mounted a CB radio to the front of it in that bin that won't hold much of anything so that when my friends and I caravan to car shows we can keep in contact without using our cell phones.
Thanks for the info! This is the console I need now I just need to find one.
Sounds to me like a little junk yarding is in order. That is always relaxing to me. Nothing like breathing the fresh air of a salvage yard and taking in the sights as well. Good luck with the hunt.
Yes agreed! I have been to a couple yards but luck on the console but have found other goodies. Thanks I will get some pics up after i'm done with it
