Separating 460/c6
Old Jun 9, 2003 | 11:28 AM
KJKozak2's Avatar
KJKozak2
Separating 460/c6
I'm thinking about pulling the 460 out of my 78 4x4 to work on it, and I can't remember exactly how to split the engine/tranny.
I thought you just have to remove the inspection plate and remove the 4 bolts holding the torque converter to the flywheel. Then just remove the bolts holding the housing to the block.
Am I missing anything?
What about re-assembly? Any tricks to that or is it pretty straight forward?
Thanks in advance!
Kevin K.
Old Jun 10, 2003 | 02:22 AM
ludis's Avatar
ludis
Separating 460/c6
You're correct. Um, er, actually, you also have to remove the starter. You'll also need to support the front of the tranny. A floor jack would be helpful while you remove the engine - you can then jack the tranny up and down to get it to seperate. Once the engine is out, jamb a 2x4 between the frame rails.
ksmith203
Feb 16, 2007 07:09 PM
KJKozak2
Offroad & 4x4
27
Apr 22, 2005 08:22 PM
Flinno18
Aug 13, 2004 11:07 AM
KJKozak2
20
Oct 6, 2003 12:10 AM
classyfish
Nov 24, 2002 12:51 AM
