1970-1977 ford
Old Jun 4, 2013 | 05:05 PM
fordcustomline's Avatar
fordcustomline
1970-1977 ford
hello,
If I bought a early to mid 70's ford f100 or f150 with a 302 with four on the floor would a 390 bolt up to the manual transmission? Im thinking it wont since the 302 is a small block and the 390 is a big block, but is it possible? and rough estimate of how much it would cost to do so. And I have heard that the 6 cylinder trucks around that time were running 4 speeds, would one of them bolt up to a 390?
Thanks
Old Jun 4, 2013 | 05:53 PM
Killgore's Avatar
Killgore
The FE series (390) are a different bolt pattern than the windsors. I think on the manuals you can just swap out bellhousings. The I6's run the same transmission as the windsors, so you'd need to find a transmission that was behind an FE.
Old Jun 4, 2013 | 09:45 PM
MeanGreen460's Avatar
MeanGreen460
Find a bell housing for a 360 390 and your trans should bolt right up.I believe that the transmission input shaft was the same for 6 cylinder and v8 engines if not you could just change the input shaft,
Old Jun 4, 2013 | 10:21 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D0TZ-7505-A (replaced C5TZ-7505-B) .. Bell Housing-Marked C5TA-7505-B
1965/66 F100/250 352 2WD / 1966 F100 352 4WD / 1967 F100/350 352 / 1968/76 F100/350 360/390.
Why buy a 1969/79 F100 or 1975/79 F150 w/a 302 and then swap engines? Just buy a 1968/76 F100, 1975/76 F150 360/390, then you won't have to swap anything.
Old Jun 5, 2013 | 08:42 PM
fordcustomline
Thank you very much for the information! and ive been looking for one with a 390 4 speed they just seem harder to find, i have some time before i do need it so i can keep looking! thank you again
privateer, eh
Oct 6, 2018 10:33 AM
flatcroaker
Jul 27, 2018 09:19 AM
1966f250
Dec 27, 2014 10:31 AM
scotjonscot
Jun 1, 2009 07:53 AM
Henryj1010
19
Apr 23, 2009 06:57 AM
