Fan nut
Old Jun 4, 2013 | 04:06 PM
jetdoc's Avatar
jetdoc
Fan nut
Is it possible to remove the fan at the nut with the belt off? I have removed the balancer and am going to install a fluidampner (had it on the shelf) but it wont fix with the fan in the way...Any ideas would sure be apprieciated!
Old Jun 4, 2013 | 04:37 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Absolutely. If you have an AutoZone nearby you can borrow their tools. Borrow both kits because you'll need one wrench from each kit.
Check out post #6 in this thread:
https://www.ford-trucks.com/forums/1...placement.html
Old Jun 4, 2013 | 04:48 PM
jetdoc's Avatar
jetdoc
Awesome!!!!! You ROCK!
Old Jun 4, 2013 | 05:00 PM
Shake-N-Bake
No problem. Thanks to Robin for posting the part numbers.
Just work them like scissors and it should do the trick. The first time I used those tools it took a fair effort to get the nut loose. I had to wear some thick gloves since the thin edge of the tools were digging into my hands.
The nut is right hand thread....so counterclockwise to loosen (like a normal fastener...).
Old Jun 4, 2013 | 05:26 PM
Christof13T's Avatar
Christof13T
Robin's trick works if you can get the wrench back there... so far i have not had any luck with that method though...
I have had good luck with a ratchet strap around fan pulley and crank pulley...
And harbor freight sells a pulley wrench for like 10$...
Old Jun 4, 2013 | 08:49 PM
jetdoc's Avatar
jetdoc
I picked up the tools tonight from auto zone so I'll give it a try in the am.
Old Jun 4, 2013 | 09:27 PM
B_Allen's Avatar
B_Allen
I have broke mine loose several times with a large punch and a hammer.
Old Jun 4, 2013 | 10:53 PM
bakerbuilttracks's Avatar
bakerbuilttracks
I normally use a chain wrench around the pulley and the correct size wrench for the nut. Mine usually busts right off. If it dose not and i can feel the wrench slipping i get a big pipe wrench and slip the jack handle over it for extra leverage that ALWAYS works
ScaldedDog's Avatar
ScaldedDog
Timely thread. I've used an air chisel before, but couldn't get that to work tonight. I ended up spraying the back of the nut with PB Blaster, and using the 54mm Autozone tool with a 1/2" breaker bar to hold the pulley, and an 18" Harbor Freight crescent wrench with a 2" pipe attached to loosen the nut. I have no idea how it got on there s tight, as I put it on last time with the Autozone tools.
Any reason not to put some anti-seize on the threads when I put it back on?
Mark
Old Jun 4, 2013 | 10:59 PM
Christof13T
Might not be a bad idea...
Old Jun 5, 2013 | 07:53 AM
jetdoc's Avatar
jetdoc
I got both kits as described earlier. The one kit with the 1 7/8" wrench was wore out. I ended up using part no 27141-3 the 54mm wrench on the bolts and a 1/7/8 crows foot on the nut. I wedged my ratchet under the tensioner pulley used a 1/2" breaker bar on the other. Worked great first attempt. Thanks guys!!
Old Jun 5, 2013 | 08:10 AM
jetdoc's Avatar
jetdoc
Off the Ace to get a longer bolt to draw this Damper down...If it ain't one thing it's another!
Old Jun 5, 2013 | 09:26 AM
mueckster's Avatar
mueckster
You may see if AutoZone has the harmonic balancer installer kit. My MAC Tools set had the proper metric insert for my installer. I just had to stack some washers on the shank to space the nut outside the damper to turn the nut and draw it down. I don't like using the bolt to pull it down. Without enough lube on the damper and bolt threads you could damage them. Also, be sure to clean and put some RTV on the end on crankshaft snout, washer, and under the bolt head to help seal it.
Old Nov 13, 2013 | 09:39 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
Found this thread. My fan nut is giving me a hard time. I'm using a chain strap vise grips to hold the pulley and big maybe 2' adjustable. Sounds like I need to add more leverage. Just don't want to break anything. Left hand threads correct?
Old Nov 13, 2013 | 10:09 PM
Shake-N-Bake
Right hand thread. Counter clockwise to loosen.
