Another Gauge Question
Old Jun 4, 2013 | 08:42 AM
rayezra's Avatar
rayezra
Red face Another Gauge Question
So I realize I really need to get gauges. I dropped 1K last week on the truck so kinda strapped.
I just read about the ScanGauge2 ($150) and think I could swing that today. Is it going to be a good gauge/scanner for now? Or just hold off until I can afford the setup below (2-3 months)?
I have researched, Edge (this one sounds good but expensive) also right now I do not want to change my tune until I get studded and gasket.
Then add Isspro fuel, oil, and boost.
Sound like a solid setup to you guys?
The others I have read a couple of post that they are not as good: Bulldog, Banks, and any others.
Clue me in on any ideas please. Thanks
Old Jun 4, 2013 | 10:05 AM
dannyboy950's Avatar
dannyboy950
Scan gauge is good but requires programming for some functions but then they all do to some extent. Several posts have been made with what to program and how to do it.
The edge insite and cts are more plug and play but more exspensive as you found out.
Ther are some phone apps as well but they require programming as well. The dashboss for Iphone and Torgue for Android there are several posts for those as well.
Some members who can help are Bismic,Bullit and Blade35 if IIRC.
Old Jun 4, 2013 | 10:42 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
If you use an iphone, iPad or itouch the Dashboss is the ticket for monitoring and about the same price as SG2
If you use a Droid phone, tablet etc the Torque App with a Bluetooth OBD adapter is the cheapest and is similar to DashBoss.
SG does an adequate job if you can get past the early 80s pocket calculator look, no recording or data logging, only 4 PIDs viewable at a time etc.
Josh
Old Jun 4, 2013 | 10:43 AM
Lilpooh's Avatar
Lilpooh
The DashBoss doesn't need to be programmed, it is "plug and play". Just plug it in, let it connect to PCM, then select the PID's you want to monitor.
Old Jun 4, 2013 | 11:01 AM
diesel_dan's Avatar
diesel_dan
Ditto with Torque Pro. While it's the cheapest by far (if you have a Droid device) at under $20 for everything, DB I think has more PIDs and so does ScanGaugeII... Oh and no way to add in external gauges on Torque either.
But you get one heck of a lot for $20!
Old Jun 4, 2013 | 11:07 AM
Bullitt390's Avatar
Bullitt390
Can add external gauges to DashBoss:
EGT
Fuel Psi
Degas PSI
LPOP
Josh
Old Jun 4, 2013 | 12:41 PM
rayezra's Avatar
rayezra
Yeah, I have no smart phone or tablet. I was looking on Craigslist for maybe an cheap iPad2 but it gets as expensive as just buying the gauges.
I guess that would lead me to a second question - Does the Dash Boss do just as good a job as an Edge and Issopro gauges would do? If so maybe I will head in that direction in a couple of months. Is there a delay and is that even relevant since it would only be seconds?
Right now just looking for an under $200 solution to get by until I can gather more money.... all I can afford right now. Or maybe just save and wait if it is not all that great - or should I say vital.
I will do a search for the ScanGauge2 programing.
Old Jun 4, 2013 | 01:04 PM
Bullitt390's Avatar
Bullitt390
There is no lag time with DashBoss.
As for gauges, the Edge doesn't have 20% of the gauges DB can do.
Josh
Old Jun 4, 2013 | 01:28 PM
rayezra's Avatar
rayezra
Cool - It will be more fun getting an Ipad anyways.
Thanks for the information guys!
Old Jun 4, 2013 | 01:29 PM
r2millers's Avatar
r2millers
EGT
Fuel Psi
Degas PSI
LPOP
Josh
However, you can only read two external sources at a time with the secondary terminal. Not a big deal as changing over to other input sources is easy with a plug/unplug process. The data you can get from this DashBoss is amazing. It's so easy to program what you want to see/use and set alarm parameters to boot.
Can't wait to use it while pulling my rig to measure data.
Old Jun 4, 2013 | 01:30 PM
Bullitt390's Avatar
Bullitt390
Currently only 2 at a time...
I was just pointing out you aren't stuck with only a couple choices or having hokey pillar gauges.
Josh
Old Jun 4, 2013 | 03:41 PM
rayezra's Avatar
rayezra
Wow watched the videos on the DashBoss and really impressed!
Ok might get an Ipad tomorrow (our secret).
Any links w/ pics on setting up the addon sensors on our trucks? I have never added anything like a egt sensor.
Also what do you recommend for the first 2 sensors?
I thank you but my financial planner might not....
Couple of good links for anyone else looking at these:
https://www.ford-trucks.com/forums/1...ved-today.html
https://www.ford-trucks.com/forums/1...ord-6-0-a.html
Old Jun 4, 2013 | 04:53 PM
r2millers's Avatar
r2millers
I bought it with the intent to first, monitor oil temp to coolant temp to ensure the oil cooler is working properly. I will eventually monitor the egt as it's directly the result of good cooling.
I would first get use to it with the existing data and add on next. Lot's of discussion of watching fuel psi too.
Amazing what you can monitor now.
Old Jun 4, 2013 | 05:10 PM
Lilpooh's Avatar
Lilpooh
Careful, your "financial planner" might want one for their vehicle also. The DashBoss will work on any CAN supported vehicle. LOL!!
Supported Vehicles | DashBoss
Old Jun 4, 2013 | 05:28 PM
rayezra's Avatar
rayezra
Yeah I should learn it first before diving in too far.
And the sigficant other is not to know (yet) or I might be missing something by morning.
Not to keep this thread from never dieing but..... Do you guys have an iPad mount you have used in your truck?
Tugly
20
Apr 2, 2015 07:53 AM
DevilDocTater
Dec 6, 2011 12:44 PM
Presa C
Mar 17, 2009 08:56 AM
suzuki_vinson
16
Sep 9, 2008 09:58 PM
mstepchinski
Dec 1, 2004 08:04 PM
