Air Bag Lite
Old Jun 3, 2013 | 12:33 PM
qtband's Avatar
qtband
Air Bag Lite
I bought this 2008 F-150 with front end damage. The bags $ seatbelts were intact. I repaired the damage and all that's left is the air bag lite. It flashes "13" for the code. I had it scanned and here is what they found:
B1231 Crash Event Detected
B1318 Low Battery Voltage At Module
B2296 Impact Sensor Fault
B2292 Pre Tesioner Fault
What do i need to do to fix this situation?
Old Jun 11, 2013 | 06:40 PM
GRNMSTR's Avatar
GRNMSTR
Try replacing the impact.sensor. It is located on the center post in front of the radiator. Make sure you disconnect the battery before disconnecting the sensor.
Old Jun 11, 2013 | 07:11 PM
tbear853's Avatar
tbear853
You'll end up replacing the restraint control module if it has any data recorded in it's non volatile memory (meaning that it's permanently recorded data) which happens if it deployed any air bags / pre-tensioners ("deployment event").
007ROADSTER
1983 - 2012 Ranger & B-Series
16
Jan 9, 2021 02:07 PM
Jamespappleton
Mar 1, 2017 07:45 AM
mustang2270
1997 - 2003 F150
Mar 16, 2009 08:34 AM
yourmineby9
Jun 8, 2006 07:21 AM
Alta
Electrical Systems/Wiring
Mar 3, 2006 12:06 AM
