ignition control module interchange??
Old Jun 2, 2015 | 12:10 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Originally Posted by bkaul
Nice diagram showing the wiring differences. I'm not sure if it's just some or all, but the Duraspark II (blue grommet) modules I've worked with have red & white wires on the two-wire connector, rather than blue & red-blue. For those, red is hot in run, and white is hot in start.
I've ran into that too. Also the red and white being swapped in the connector, something else to watch for.
Old Jun 2, 2015 | 12:15 PM
Shortcircuit's Avatar
Shortcircuit
Thanks for the diagrams. But this engine is a distributorless ignition system, with no place to drive a distributor. Just a 4 tower coil that fires 2 cylinders at the same time. One on the compression stroke and one on the exhaust stroke. It has a single 23 pin connector with 13 wires attached. The Coil has a 3 wire connector. I assume the center wire is ground and the two end wires fire the two sections of the coil being a 4 cylinder system. Thats why I thought I could swap the end wires and test the other half of the coil to make sure it's not the problem, even though it is new. Any luck on a motorcraft part number on the ICM?
Old Jun 2, 2015 | 12:33 PM
bkaul's Avatar
bkaul
Nothing like that was ever offered on these trucks ... you might try asking at your local Ford dealer?
Old Jun 3, 2015 | 09:49 AM
ZarK-eh's Avatar
ZarK-eh
This would be another post on it's own. Nothing like this ever offered on dentside ford trucks.
I am guessing if it's a distributorless setup, that there is some form of crank trigger to signal when to fire.
Good luck with this!
Old Jun 3, 2015 | 02:16 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
A little off topic.
I am looking for a Motorcraft Number for an ICM on an industrial ford 1.3L 4 cylinder.
The Ford Module has an engineering number YU1L-12A297-FA
Call a tractor dealer and get the correct part number. I believe the above has been replaced.
ved0303
Apr 7, 2023 04:46 PM
78Hayride
Jan 8, 2019 04:44 PM
dwhawkins89
Dec 22, 2017 07:07 PM
Pryan68
Jul 16, 2016 03:43 PM
George Frasier
Jul 18, 2010 06:19 PM
