Gas Gauge issues
Old Jun 2, 2013 | 03:27 PM
Kyle Hartman's Avatar
Kyle Hartman
Gas Gauge issues
Hi all I have a 2004 F-150 and the gas gauge seems to be stuck on a half tank, sometimes it will go to full tank. How do I fix this.
Old Jun 2, 2013 | 03:57 PM
danorules's Avatar
danorules
Do a search, I remember reading an easy fix for this. Gas dry for 2 tanks or something simple. But you may need a new sending unit. The truck is almost 10 years old
Old Jun 3, 2013 | 03:52 PM
2004 xlt 5.4's Avatar
2004 xlt 5.4
did this happen a while back ? or at last fill? if at last fill was the truck shut off and the key off
I found when fueling up all needs to be off I now pull the key when fueling
or gauge will not go to full and stick somewhere in between for at least a day or two.
Old Jun 4, 2013 | 07:30 PM
UncleTom's Avatar
UncleTom
I posted on here about my gas gauge problem a couple of months ago. The fix was i took it to the dealer and it was the sending unit. It is an 08 with 32000 miles on it. Also had them fix the heater. It would get hot but when you go to turn the temp down it would still be hot. Turn it down a litlle more and it would go cold. It turned out to be the blend door actuator. It all works now.
jowilker
Jul 31, 2021 07:23 AM
Jim Beckers
21
Sep 19, 2014 01:04 AM
boomerSS
Oct 14, 2010 06:24 AM
phatkat
May 5, 2008 09:31 PM
65f100_352
Jan 7, 2008 04:42 PM
