gas gauge
Old May 5, 2008 | 06:24 AM
phatkat's Avatar
phatkat
gas gauge
My gas gauge is stuck on empty I think it mite have a hole in the float but would like to check the gauge before i pull the tank I heard that i should ground the gauge at the sendig unit how exactly do you do that.
Old May 5, 2008 | 04:18 PM
Dr. Dirt's Avatar
Dr. Dirt
one time my gas gauge was stuck on empty right after I put 15 gallons in it. is there still gas in the tank?
Old May 5, 2008 | 06:36 PM
Tedybear's Avatar
Tedybear
Go to the sending unit with a jumper wire attached to a good ground. Follow the wire from the sending unit, and you should find a connector. Have a helper watch the gauge with the trucks ignition 'on' but not running. Ground the connector for a few seconds and the gauge should start heading up.
Ohh...don't screw up like we did at first!! We removed a gas tank on ours for the exhaust---and had the tank selector set for the fuel tank we removed. LOL.
S-
Old May 5, 2008 | 09:31 PM
phatkat's Avatar
phatkat
thanks thats a big help. and it does have gas still in it
mojo79
Nov 15, 2010 07:16 PM
willette1962
2004 - 2008 F150
Oct 20, 2010 11:27 AM
mosgo1
Electrical Systems/Wiring
Nov 19, 2008 08:02 PM
dotcentral
Jan 14, 2008 10:07 AM
bmxerbrett
Jan 1, 2006 11:38 AM
