Aerostar Ford Aerostar
Support Mount Bushing
Old May 31, 2013 | 03:59 PM
Steve Aerostar's Avatar
Steve Aerostar
More parts needed as we get deeper into this overhaul. For a 1996 Aero, electronic all wheel drive, 4.0 VIN 1FMDA41X3TZA74087. Need support mount bushings FO9Z3A443A. I found one in PA, looking for another one. You can also contact me at my email address, sbeck112@bright.net
Thanks
Steve
Old May 31, 2013 | 10:28 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Need support mount bushings FO9Z-3A443-A / I found one in PA, looking for another one.
When the second digit of a part numbers prefix is a zero, it can also be typed as the letter O.
FO9Z-3A443-A = MANDERBACH FORD in Temple PA has ONE = 610-929-3683.
F09Z-3A443-A = B & B AUTO PARTS in Bronx NY has THREE = 718-892-1186.
No other Ford Dealer or obsolete parts vendor has any.
Old Jun 1, 2013 | 09:53 AM
Steve Aerostar
Thanks, B & B had two and I purchased them, Manderbach Ford does have one piece. Still lookin for the FO9Z6A023C transmission cross member.
Steve Aerostar
Old Jun 1, 2013 | 10:30 AM
NumberDummy
FO9Z-6A023-C = 1990/97 Aerostar 4.0L / Obsolete
No Ford Dealer or obsolete parts vendor has any.
Old Jul 13, 2013 | 04:19 PM
prof77's Avatar
prof77
Need two Aerostar Support Mount Bushings - Ford part # F09Z-3A443-A
Hi - We need two (2) Support Mount Bushing kits for a 1997 Ford Aerostar AWD; Ford part # F09Z-3A443-A. Please contact me at prof77@aol.com if you know where I can get them! Thx - Norman
PS. Is there any other part that can be made to work?
Old Jul 14, 2013 | 12:46 AM
96_4wdr's Avatar
96_4wdr
best to PM numberdummy directly. he has an IN to the Ford corporate parts system
Old Jul 14, 2013 | 04:53 AM
NumberDummy
See posts 2 & 3.
Old Jul 14, 2013 | 03:23 PM
xlt4wd90's Avatar
xlt4wd90
I'm sorry for being somewhat clueless on this, but can someone tell me what mount they are talking about here?
Old Jul 15, 2013 | 06:10 AM
asavage's Avatar
asavage
FTE Community Team
I don't know that the "Support Mount Bushings" are, but I recognize this one:
That's the transmission support crossmember.
Click here for larger
Old Jul 15, 2013 | 03:40 PM
xlt4wd90's Avatar
xlt4wd90
I know about the transmission cross member; the hollow bushings in mine are sagging as well. Are the 2wd and 4wd versions the same?
Old Jul 15, 2013 | 06:56 PM
asavage's Avatar
asavage
FTE Community Team
AFAICT, the crossmembers are the same across RWD & AWD, from '90-on. The lowest one in the pic above came off a '92 RWD, and it appears the same as the others.
I've got one of the bushings out and on my desk right now. I looked into buying a bushing to replace them, but haven't found a good one yet. ATM I'm thinking of buying some Flexane and pouring it into the shells.
It would be trivial to bold the crossmember solid to the frame, but I'm looking for a solution that still allows some flex and vibration isolation.
Old Dec 18, 2024 | 06:11 PM
colinmcc's Avatar
colinmcc
How did you proceed? I have a 95 AWD and 94 2WD both have the bushes totally gone. Been trying for years to find a good used X member, or bushes, but not a hope now. Did you manage to cast something in to make the assembly more solid?
Old Dec 18, 2024 | 06:40 PM
asavage's Avatar
asavage
FTE Community Team
I used a Dremel (small die grinder) and cut away the sort-of large spot welds that retain the bushings into the crossmember, and then pressed them out, rotated them either 90° or 180°, depending on what worked best, and pressed them back into the crossmember. I could get a couple more years out of them that way, and then I sold my last (of five) Aeros, in 1997 -- replaced with a '10 Sienna AWD, which I still own.
[later]
LOTS more info and pics I posted are over here:
https://www.ford-trucks.com/forums/1...l#post13326410
moroza
Large Truck
May 20, 2016 04:25 PM
wareagleF100
Sep 1, 2010 03:48 PM
justinfown1
Sep 12, 2009 02:46 PM
llewsac
Jun 10, 2009 09:18 AM
itsmywifestruck
Mar 14, 2009 07:24 PM
