96 Aerostar Transmission Crossmember
Fixing up my fifth Aerostar. This is a 96 I purchased out in Denver two years ago. The timing chain cover is leaking coolant and now we are doing a somewhat medium overhaul of the engine. To remove the engine and 4WD trans we had to take out the crossmember support. The rubber bushings on one end are totally gone. Searching for a new crossmember yielded no luck at dealers and on the net. Does anyone have some suggestions for aftermarket crossmembers or a possible source for a OEM piece. The part number for the crossmember is FO9Z6A023C.
you can email me direct if you would like
sbeck112@bright.net
Thanks
Steve
sbeck112@bright.net
Thanks
Steve
Try Green Sales Company Green Sales Company - Obsolete Ford parts, Lincoln, Mercury parts Green Sales Company, supplier of obsolete Ford parts and Lincoln / Mercury parts.* Our Ford parts inventory represents all Ford and Lincoln / Mercury products from 1950 to the present.. They specialize in obsolete OEM Ford parts. Your best bet is to call them. Their website search engine does not work well - in my opinion. I've used them twice with good results but they are a little pricey. I picked up a new crossmember a few years back by special order from a dealer. I imagine most Aerostar parts are listed as no longer available and a lot of parts guys don't want to spend the time to search for you. Also, if he is still around, NumberDummy, was a really helpful member and a Ford parts guru. Might try contacting him if he is still a member.
how to contact numberdummy
Do a member search and it shows how to email him or send him a PM. He is still active and I saw where he has logged in today. I needed his help several years ago and he came through for me.
On my '89, I used an air hammer to knock the old bushing out of the crossmember, and I put "better" ones in from a later crossmember. I don't recall if I had to Dremel off a couple of welds on the bushings or not to remove them.
On my '93, I paid for a new crossmember.
Now, I have the same problem on the '97:
Click here for larger
Fortunately, armed with that part No. (FO9Z6A023C), I was able to order it from FordParts.com . I used the option to supply my VIN, so if it's not the correct part, I should be able to return it. It was about $80, which considering that I paid a lot more than that for the one I bought for my '93, I thought was quite reasonable.
Now I've got to go order the trans mount.
Look at the pics above: they are elaborate bushings with integrated outer shells that are thicker than usual. You're not going to just machine a replacement that still has any elasticity. I've given it considerable thought. I'd rather source the factory part; any fab'd replacement is not going to provide any NVH damping.
