Sponsored by: Real Truck
Wind noise
Old May 31, 2013 | 06:35 AM
Rlisby's Avatar
Rlisby
Wind noise
I just bought a 2009 F250, I am getting a wind noise that I can't figure out where it is coming from. It only happens when I'm going at least 70 and into the wind. It is a short flute sounding noise that is intermittent. Any help would be appreciated.
Old May 31, 2013 | 07:57 AM
redford's Avatar
redford
FTE Leadership Emeritus
What engine and cab do you have?
Old May 31, 2013 | 08:08 AM
Rlisby's Avatar
Rlisby
6.4 diesel crew cab
Old May 31, 2013 | 11:10 AM
redford's Avatar
redford
Does the flute sound change with throttle input?
Old May 31, 2013 | 11:27 AM
droldsmorland's Avatar
droldsmorland
Or it could be head wind getting under the windshield gasket. Sounds similar to putting a blade of crab grass between your thumbs and blowing? Mind did it too. Take it to a reputable auto glass installer and describe the problem. I do know the guy who fixed mine struggled with it but fixed it. I think he pulled the plastic outer gasket and filled the gap between it and the bed then snapped the plastic gasket back on and let the calk cure. My truck has had almost all of the annoying little nickle/dime problems listed here and counting...sigh.
Old May 31, 2013 | 11:47 AM
JohnnyThunder's Avatar
JohnnyThunder
Interesting, my 11 does the same thing. I will have to check into your fix.
Old May 31, 2013 | 12:07 PM
Rlisby's Avatar
Rlisby
It doesn't change with engine rpm
spacetiger
Nov 7, 2017 11:26 AM
Hitokori
25
Feb 17, 2011 09:20 AM
K.O-T.O
2004 - 2008 F150
Apr 27, 2008 10:50 AM
