Temp jumping
Old Aug 18, 2013 | 04:49 AM
tiap's Avatar
tiap
One reads stories about impellers slipping and falling off etc, if that really happens at all, I doubt it's very common.
The impellers on these pumps are just a paddle design, the poorest design of all, especially at idle. Best would be a cupped directional.
The last new pump I bought, I put it in a hydraulic press and pressed the impeller as close to the casting as possible, without having the blades hit. I moved approx 1/8" on the shaft.
Don't know how much this helped flow in numbers, but I guarantee it improved it, especially at idle.
I would suspect the condition of the airflow thru the rad more than anything. A good shroud sealed as best as possible to the rad. Perhaps find a better fan with more blades with more pitch. If you're using a fan clutch, check that, they should have less slip the hotter the air thru the rad gets.
1owner72
1997 - 2003 F150
13
May 29, 2016 09:05 AM
aharleycpl
Dec 31, 2015 10:35 AM
Phantez
Dec 7, 2012 10:02 AM
gpfarrell
17
Nov 29, 2005 09:40 AM
momofcrts
Aerostar
Aug 26, 2003 06:10 PM
