T-19
Old May 30, 2013 | 07:23 PM
mudguts's Avatar
mudguts
T-19
T-19 started making noise like something is loose just started all of a sudden, mainly in 3rd gear and has less noise in 4th. topped off Gear oil, it took about 8 ounces, Right now it's just annoying sill shift's fine. any help would be appreciated.
Old May 30, 2013 | 08:40 PM
turtlemann14's Avatar
turtlemann14
it's probably just a bushing that is worn.
is it kind of a wallering/whiring noise?
Old May 31, 2013 | 05:13 PM
mudguts's Avatar
mudguts
It's just a vibration shifter does vibrate a littel not really a whiring or wallering noise. Thank's
Old May 31, 2013 | 06:28 PM
hairyboxnoogle's Avatar
hairyboxnoogle
Countershaft bearing?
Old May 31, 2013 | 06:34 PM
mudguts's Avatar
mudguts
I just drove it again and I did hear a deep whiring noise.
Old May 31, 2013 | 06:45 PM
Bonanza35's Avatar
Bonanza35
I say bearing of some kink. Mitt be time to pull it apart and inspect!
Old May 31, 2013 | 08:44 PM
joshofalltrades's Avatar
joshofalltrades
sounds like you'll want to buy a bearing and seal kit and tear into it. if you're gonna replace one bearing, may as well replace them all.
Old May 31, 2013 | 09:36 PM
mudguts's Avatar
mudguts
Yes I thought I might end up having to tear it down and fix it. I have rebuilt these engines but have not ever tore apart a gear box any one know of a good manual? Thank's Mudguts.
Old Jun 1, 2013 | 12:29 AM
joshofalltrades
i haven't had a t19 apart myself, but i have had a handful of other trannies apart. you'll want a good assortment of pullers and maybe a small hydraulic press, as well as a solid set of snap ring pliers. from there, just keep everything in order and facing the right way.
maybe someone else has a manual for it, but i don't
Old Jun 1, 2013 | 11:50 AM
mudguts's Avatar
mudguts
Thank's sound's like rebuilding a carb, I have a friend who is a machinst That has a shop. (he used to build NASCAR engines) so he will have any presses or puller's that I may need, I used it today to pull my 2 yard concrete mixer and it was quiter under load.
Old Jun 1, 2013 | 12:06 PM
hairyboxnoogle
you uses presses and pullers for rebuilding carbs o.0 lol
Old Jun 1, 2013 | 12:31 PM
joshofalltrades
of course we do they're just a lighter duty version of presses and pullers, which are sometimes referred to as fingers
but i get what he meant, the careful laying out of parts in order, all that stuff, yeah, just like doing a carb or anything else you're not totally familiar with the internal workings of
on other trannies i've had apart, you would swear that every darn piece is pressed onto the shaft, and in some cases i've had to use two pullers together to get something off.
i highly recommend having 2 large tables for your workspace, one of which sees active work, and the other to store parts in order.
Old Jun 1, 2013 | 12:36 PM
hairyboxnoogle
I know what he meant to, just givin him some crap
Old Jun 1, 2013 | 02:17 PM
Chevy_Eater's Avatar
Chevy_Eater
I have a carb that looks like someone did just that. I'll have to get some pics.
Old Jun 1, 2013 | 06:47 PM
mudguts's Avatar
mudguts
Me being a Concrete Guy I just use my sledge Hammer for small and Delicate part's. Oh yeah and when in doubt add more portland! lol.
