Replace Egr cooler only?
#46
Sometimes you just got to Dive In
And the Tunner came out the closet or Did I miss that LOL
Now Lets Hope they Don't Find a Bad Head At 1K Apeice
You Should STRONGLY CONSIDER Doing a COOLANT Flush BEFORE It Goes In
Stuff a Hose In IT!! Open the Drains and let it RIP FULL ON
since you cant run it Much With Blown EGR Cooler
Just Tell them you want to drain cooling system Water ASAP Block Drains and ALL When you get there It will rust Fast So Just get water Out
Your Main Goal is to end up with a Spotless cooling system
Lots of ShOPS tell you how well they will Flush and all they Get is a Spill-N-Fill
The Best thing here is to end Up with ELC
ELC=Extended Life Coolant
Oh Ya Tell them you still WANT The EGR VALVE INSTALLED and Plugged IN!!
#47
#49
#51
#52
So Great Better Take the Wife out to Dinner your 400 ahead
Mine always says you spend more on that truck then Me When I Bought the EGR Deleate was straw that Broke the Camels Back LOL
#53
He has to Pull the Injectors out or should
But may leave in to save Him a Penny IDK
But Now would be a Great Time to Clean Injector Spool Valves up
Stiction Fix
Must read, Instruction and Video
Also be a Great Time to change Top Injector Oring to the HPO Rail when you have the injector out
Stiction Fix
#55
53k, Im gonna have them dissemble turbo clean etc. Injector test and new o-rings. Basically the quote they gave my included a 6.0 solution kit. Has a bunch of o-rings and gaskets in it. Not sure if all of it is necessary though.
Also ford has an updated turbo drain tube and feed tube, are these things i should consider?
